× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Which wi-fi extender works with AT&T
jmb3810
I need to get a wi-fi extender. Which is the best to get for an AT&T uverse aaris NVG589.
Thanks
Message 1 of 5
Guru
Re: Which wi-fi extender works with AT&T
Thanks
This is an N300 router (single band, 802.11N).  A WN3000RP would work (and is the same speed as your router).
Can you give us some more info on what you are thinking of doing -
  • If you are trying to cover a dead spot?
  • If you are wanting to provide ethernet for a device that has no wifi?
  • Something else?
Either way, how far away is the spot you are trying to reach, and what obstacles are there between that spot and the router?
Message 2 of 5
jmb3810
I installed a Kuna security light and it needs a wi-fi signal. The signal gets very weak when it reaches the front door from the back of the house.
Message 3 of 5
Guru
Sounds like the WN3000RP would be reasonable then.  Place the extender towards the front of the house (close enough to the router to get a good connection to it, but also close enough to the Kuna to reach it).
Message 4 of 5
jmb3810
Thanks so much!
Message 5 of 5
Discussion stats
  • 4 replies
  • 1004 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
