GRANBOB's avatar
GRANBOB
WiFi Range Extender
I am having trouble connecting my range extender to my new telstra nbn router TG799ua  .
is my exteneder compatible with a testra nbn router
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello GRANBOB
    It should work make sure you are using wpa2 security on your wireless password and try both ways of connecting the device the manual setup and the WPS. If you provide the extender model number I can get you the setup guide you need.
    DarrenM
