× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
compatibility
rosdol
Follower
compatibility
help please
I have above bought in California when I lived there.  Back in europe and plugged in with a 240V powwer source - switched on fine and  is recognised by laptop but will not connect with a french livebox router?
also can one connect two boosters to same router?
thanks
Model: WN2500RPv2|N600 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: compatibility
You may want to factory reset the extender by holding the reset button for 10 seconds then try the setup again. And yes you can use more than one and it is recommended to have separate SSID for each one.
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 256 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
