stubby
Nov 28, 2018Guide
ex6100 speed stuck at 150mbps
I just completed the setupe for the range extender and have been testing sppeds throughout the house on the old 5g and new ext5g.
when in the same room as the router on 5g from router speed is 300mbps, when on the 5g ext speed form extender is 150mgps max.
Are settings that need changed to fix this?
Is this measured throughput, or are you reporting the wifi link speeds?
Is the router 802.11n, or is it 802.11ac?
- stubbyGuide
router is 802.11n
speed I am reporting is from the wifi access connection
right now 300mbps on 5ghz from router wifi
and 150mbps when on the ext5g exntender channel
