ute_zi's avatar
ute_zi
extender refuses client connection
I extablished a connection from the extender WN3000RP to my Fritz!Box 5330 via WPS (2.4 Ghz)
and I can connect to the extender web page via its assigned IP address.
I can not connect any client to the extender using Wi-Fi
When trying to connect any mobile client to the extender it says "Couldn't connect to network"
connecting any mobile client to the Fritz!Box is not a problem.
The extender was working fine for years till about 2 weeks ago
factory reset was done on both, router and extender but did not help
any help would be greatly appreciated!!
Merry Christmas
Extender Status
Hardware VersionWN3000RPv1h2
Firmware VersionV1.0.2.64_1.1.86
GUI Language VersionV1.0.2.64_2.1.9.1
Connection Status to Existing Network
Name (SSID)BLUB
Link Rate300 Mbps
Connection StatusConnected
  • plemans's avatar
    Try setting up the extender using the installation assistant and not WPS.
    • nielsvds's avatar
      nielsvds
      Luminary
      You should also check the passphrase that is used in the extended network that it is still the same as that of your existing router. When doing the smart installation don't forget to check the box use the same security ...as those of the existing network.
      • ute_zi's avatar
        ute_zi
        thank you nielsvds for your response!
        Setting up a connection between the extender and the router is not a problem.
        And all settings (security and passphrase) are the same.
        and they connect without problems any time, like after an off/on of the extender or the router.
        its the mobile client side were the problems are
        they have the same settings (security and passphrase) but fail every time connecting to the extender.
        connecting the mobile clients directly to the the router using those (same) settings is not a problem.
    • ute_zi's avatar
      ute_zi
      thank you plemans for your reponse!
      connecting the extender to the router is not the problem.
      using WPS or the assitant, it always connects without problems.
      conneting the mobile clients to the router works as well without problem.
      it is when I want to connect the mobile client to the extender that I cant connect.
