Jess_P
Jan 03, 2019Follower
wrong password
Hi,
I have recently bought the wifi range extender EX2700|N300, I've set it up through WPS and everything looks as it should. However, when i type the password for the orginal router (as it says) it keeps saying incorrect password? Does anyone have any suggestions? It would be massively appreciated.
thank you
1 Reply
Try resetting the extender, and this time don't use WPS. You'll see a network called NETGEAR_EXT, which you join. You then browse to www.mywifiext.net to complete the setup.
This is described in the user manual on page 10 - Connect with Web Browser Setup. http://www.downloads.netgear.com/files/GDC/EX2700/EX2700_UM_EN.pdf
