× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
2.4GHZ Band not broadcasting
mgeorge
Guide
My Netgear is not broadcasting the SSID on the 2.4GHz range. It says its enabled but it no devices can see it. My 5 GHZ band is fine and working. I am on the latest firmware I think at V1.0.2.80. It was working all day and just stopped. What is going on?
Model: WNDR4300v2|N750 Wireless Dual Band Gigabit Router
Message 1 of 8
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: 2.4GHZ Band not broadcasting
Try to re-upload the latest firmware once again and then reset.
Once done, reconfigure the router and see if you can get it up and running again.
Message 4 of 8
All Replies
ElaineM
Welcome to the community, @mgeorge
What's the exact model and version of your router? Is it WNDR4300 or WNDR4300v2?
Is the 2.4GHz light still on or off?
You may want try to reinstall the firmware and then do a factory reset afterwards.
Message 2 of 8
mgeorge
Guide
It is not the v2 and the 2.4GHz light is illuminated.
Model: WNDR4300|N750 Wireless Dual Band Gigabit Router
Message 3 of 8
ElaineM
Message 4 of 8
mgeorge
Guide
    That seems to have fixed the issue, thank you.
Message 5 of 8
ElaineM
Thank you for the update.
Do not forget to mark the solution.
Have a great day!
Message 6 of 8
mgeorge
Guide
This issue has returned. For some reason the 2.4Ghz signal des not let anyone connect to it however the 5Ghz signal works fine. When I log inot the router everything shows green like it is wokring but it is not. To avoid any confusion it is happening on IOS and Windows devices.
Model WNDR4300|N750 V2.0
How would I attach the logs?
Message 7 of 8
ElaineM
How long have you had the router?
Firmware reinstallation should have corrected this already but if you're saying that it comes back then the router could be faulty.
If this is still under warranty, get an RMA.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 22302 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
