× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wifi Extender Setup - WRT1000v4
THowe683
I am looking to use a WRT1000v4 as a wifi extender to my existing Netgear WNDR4500v3 wifi router.  I cannot seem to find instructions on how to set it up.  I did see a setting under Advanced / Advanced Setup / Wireless Repeating Function.   I set my WRT1000v4 to 192.168.1.2 (not used on current wifi) and input the MAC address of the WNDR4500v3 router.  I cannot seem to get the two to talk.  Any suggestions would be appreciated.
Message 1 of 6
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Wifi Extender Setup - WNR1000v4
Both should have wireless repeating in order to set it up completely.
The only way to extend the signal is to connect the second router with an Ethernet cable from main router.
Message 6 of 6
All Replies
ElaineM
Re: Wifi Extender Setup - WRT1000v4
Welcome to the community, @THowe683
Can you verify the model WRT1000v4?
It seems that it's not in our list of routers/extenders.
However, to setup wireless repeating you can use this article as a guide.
Message 2 of 6
THowe683
Sorry, my two models are:
Netgear 75 / N900 (WNDR4500v3) - main router connected to broadband modem broadcasting 2.4 Ghz and 5 GHz
and
Netgear 38 (WNR1000v4) - spare, want to use as a WIFI extender for 2.4 GHz
Model: WNDR4500v3|N900 WIRELESS DUAL BAND GIGABIT ROUTER
Message 3 of 6
ElaineM
Do you the Wireless Repeating options on both routers?
If you do, did you follow the link from the previous post?
Message 4 of 6
THowe683
Thank you for the response.  However, on the main wifi router I do not see the option to set up as a base unit.  There is no option under Advanced for Wireless Repeation Option. I have an option for Wireless AP or Wireless Bridge.
Message 5 of 6
ElaineM
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3012 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
