Access point
5 TopicsAdvantages/Disadvantages to using Orbi RBK50 pair as Wireless Access Points
I use an xFinity wireless router/modem for internet, wireless and VOIP. I understand that I could use the Orbi RBK50 units as access two wireless access points for this router, but am wanting to know what the advantages and disadvantages are of this and whether I would possibly be better off disabling the xFinity wifi and just going with the 2 Orbi's. I realize that going the access point route would potentially give me more coverage (3 wireless signal senders instead of 2) but wonder if I would be losing out on some functions or features by doing this. Thanks in advance.Orbi or Nighthawk with access points?
Hello, I'm really seeking some good solid advice here folks regarding upgrading my existing Apple AirPorts to a mesh or router with access point system. I'm not a big pro here, I do know some as you'll see below. But, I am definately drawn to the convenience of the mesh system all working together in one app with easy setup etc. After much effort, my Airport setup still dissapoints with frequent slow loading video, poor range overall etc. It's time to upgrade. Here's my situation: Currently: 1. I have 1 Airport Extreme and 2 Airport Expresses. Airport Extreme connects via thernet to both Expresses, cable I've run one way or another when using them as repeaters wirelessly failed miserably. It's a pretty big house I'm covering here. 2. Whats so important is that I have MANY many devices connected well beyond phones and tablets. I need a router system that can handle that. Also, I need a system that can handle playing music via AirPlay through iTunes flawlessly. Currently, my wired speakers handle it great and my 4 wireless speakers work 90% of the time, which is acceptable, barely. I've read that Orbi has had some issues with reliability when it comes to airplay, so that's a concern. Scenario 1: Orbi 1. Replace the 3 Airports with a 2 unit Orbi system. I could still keep my Airport expresses connected in bridge mode and use them for airplay speakers, connected via ethernet branched off the main router. The wifi would need to feed the rest of the wireless speakers in the house however. 2. I currently have 3 WIRED locations, and with Orbi I cannot connect them via ethernet for the backhaul, it MUST be done via wireless tri band. So, this begs the question, is Orbi SOOOO good and reliable that even running wirelessley it's better/as good as a router with wired access points? Will the backhaul required when using airplay suffer since the rest of the system is forced to use the wireless backhaul and not ethernet? Or is it all just so amazingly perfect and range extending that it will all beat the 3 Airports I have spread through my 3,000 sqft home? Scenario 2: Nighthawk plus access points 1. I could easily just swap out my existing 3 units for 1 Nighthawk AC3200 router and 2 AC1900 access points. Is there a system that is already bundled or MADE to work flawlessly together in this configuration? Netgear recommended a powerful Nighthawk but the only "access point" type device I could find was the AC1900, which is dual band while the router I would get would be 3 band. 2. this begs the question, what is the TriBand used for in a wired system? Is it used to manage traffic better or is it relatively pointless as it's there to run the backhaul for wireless devices, and since I'm wiring all 3 of them together, this Tri Band dream I'm holding onto is irrelevant? Should I just get a strong dual band with dual band extenders and call it a day? 3. Again, I'd really like this to be somewhat future proof, I don't want to bother with the wifi again for a long long time. I want it to be able to grow and handle it. I'll throw a decent amount of money at it to get that too. Please, any other model configuration or brand suggestions are VERY welcome. Lastly, I know the Eero system supports the ethernet backhaul (and maybe even the Velop). Is there a benefit to a wired mesh system OVER a wired routher/access point system? Many thanks for any advice, thanks for your time, I know it's not a short post:-) Rob I'Will Orbi Satellite work with existing Netgear Nighthawk X8 router?
I recently purchased a Nighthawk X8 router, so I don't need an extra router. My X8 is placed in the center room of our house. Our home built in 1926, is 3,000sq' it has older plaster walls & the wi-fi reception barely reaches through more than 1 wall. Wireless repeaters didn't seem to work, nor the powerline extenders, so I just had someone hardwire a Netgear AC1200 in order to have wi-fi in the family room. Seems to work great but the signal drops near the rear of the house, so I'm thinking to either hardwire another extender as an additional access point, but I would like to have a single mesh network, which switches automatically (so we don't have to sign on to the extensions whenever we move about the house with a laptop) Can I create a single mesh network using the X8 & the AC1200 I just purchased? Or I see the new Orbi Satellite which looks great & has the capability of a single mesh network, but will it be compatible with my existing Netgear Nighthawk X8 router?Can Orbi be put into bridged mode?
Hey All, I currently have Netgear Nighthawk X8 Wireless Router with 5 x eeros (set to bridged mode - to avoid double NAT - so essentialy they act as wireless access points). I have it setup this way because of the link aggregation offered by the Nighthawk X8 - my NAS is plugged directly into it using a ethernet bond. So until these mesh technologies create a router that supports link aggregation / bonds I need to keep using my Nighthawk X8 + some sort of mesh to cover my house and workshop. Details - I am trying to cover about 4000sqft + house features are preventing line of sight and also have a tendency to degrate a wifi signal (i.e. my office is almost a faraday cage; when it was built it was covered in the radient barrior stuff to keep heat or cool in - this creates a crazy effect where wifi signals are "blocked" in an out - good for security bad for wifi ;). I have run hard lines to solve that problem - but wireless devices are still impacted. So here's the challange: eero setup works great because it allows me to set the primary node to bridged (good) and allows my Netgear to hand out IPs and it has a few parental features that are disabled because of it and I need about 5 nodes to cover my area (bad) Luma has good parental features (good) but does not support a bridged mode so I cant use ling aggregation on my Nighthawk X8 and I would need about 4-5 nodes to cover me (bad) Orbi seems to have the coverage thing licked (though I have never used one -yet) and I cannot find any information on parental controls or if the router can be made into an access point, i.e. bridged mode. So my questions are: Can the Orbi be put into bridged mode so that I can continue using my Nighthawk with link aggregation for my NAS Is there a better way to set up my network? Like putting the Nighthawk into AP mode - I think I ran into issues with that with the eero because I could not change the default gateway so I effectively had 2 networks 192.168.1.x and 192.168.0.x (bad) Any help / thougths would be appriciated! Thanks!Solved
