Bridge mode
4 TopicsXR500 as wireless ethernet bridge
I want to setup my XR500 as a wireless ethernet bridge. Why? Becuase I have an XR500 and 4 devices that do not have WiFi adapters in a room that I can't run a wire. I know I could use a cheaper router to do this, but I already have an XR500. I don't need to use the wi-fi on my XR500, except to brigde to another router. (If I could run a wire, I would use a 5 port Gb switch) Netgear has instructions for how to set up a router in bridge mode: https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router But I think these instructions are not for the XR500. Any help is appreciated.8.9KViews0likes7CommentsR7000 in bridge mode (AP) with Disney Circle
Hello, I have a R7000 router, in bridge mode wich is connected to my ISP supplied modem, a Huawei brand. I need to have the Huawei connected becuase it has a VOIP connection and the R7000 doesnt. I want to use the new Disney Circle, however when I go to connect to the R7000 via the iOS APP it says that I cant connect to the R7000 when it is in AP or Bridge Mode. My question is. How can I use Disney Circle (full paid access) with my current setup. Are then any settings or hardware changes I can do? I know I can remove the Huawei, but I will lose my VOIP.2.8KViews1like3CommentsR6400 in bridge mode
My R6400 is not communicating with the "little black box" of our internet provider... rise broadband. And the second light from the left is not lighting up. I first thought it was a problem with rise but everything was working fine on their end and they believe the problem is my router went into "bridge mode." So what can I do to fix that?SolvedSetup R7000 in Bridge Mode
I upgraded my R7000 firmware from 1.0.4.28 to 1.0.7.6. I had my R7000 setup as a bridge before the upgrade. I logged into the router after the firmware update and the bridge setup now has its own section under Advanced setup instead of being a Use other operation mode check box and configuration under Wireless settings. It is totally different than the previous configuration and only the old configuration method is covered by the R7000 Users Manual. I have tried without success to configure the R7000 as a wireless bridge. There is no configuration section to input the parameters of the R7900 5G network I am trying to connect to. Can anyone help out with this configuration?Solved9.8KViews0likes3Comments
