DNS
29 TopicsFeature request: DNS privacy
While it's great that we can designate our own DNS servers on the routers, instead of just using the ones provided by our ISPs, it would be even better if you could integrate DNS-over-TLS and/or DNS-over-HTTPS into the firmware. This would allow us to query DNS servers (e.g., Cloudflare's 1.1.1.1 or Google's 8.8.8.8) without our ISPs being able to monitor our requests, giving us confidentiality from our ISPs and anyone along the path between our LAN and the DNS server; without our requests being able to be changed, ensuring integrity in the replies; and without having to run a separate service or piece of hardware on our networks for this purpose, increasing availability, at least from a certain perspective, as not everyone has the resources or ability to run their own local DNS server capable of using one of these two standards.17KViews82likes33CommentsFree DDNS providers, dynu/duckdns etc
Please give us the option to add free DDNS providers. Alternatively, the providers have APIs, and so a method to manually add to the DDNS provider selection. My particular interest is with Netgear ORBI (RBR50) NB The forced idea labels are very restrictive426Views1like1CommentAllow setting of DNS search domain
I have an Orbi RBR350 (https://www.netgear.com/support/product/rbr350) but I assume this will apply to others as well. I can set the DNS server to our local DNS server but I cannot set the search domain. As it therefore doesn't tell clients the search domain, I need to configure them all manually. Hopefully a future firmware upgrade could introduce this feature.631Views0likes5CommentsPi-Hole as an app/plugin for Netgear Orbi
I think it would be pretty awesome if Netgear made their Network devices like the Netgear Orbi support the free software called Pi-Hole via an app/plugin support feature on the device itself. For those that dont know Pi-Hole is a FREE network wide ad blocker that you install on a Raspberry Pi and then after its installed on Raspberry Pi you connect the Raspberry Pi to your router and setup the Raspberry Pi as the DNS server. I would love to see Netgear make Pi-Hole compatible with their devices without having to buy a Raspberry Pi, maybe add it as a plugin or addon that you can install on Netgear devices? This is the link where you can learn more about Pi-Hole Link: https://pi-hole.net/3.4KViews9likes3CommentsDHCP Configuration / DNS Configuration
R7900 - Requesting additional DNS configuration within Router Setup Configuration. I only see one place to set the DNS and I believe there needs to be two. One for what DNS server(s) the router itself should use and a second entry for setting what DNS server(s) the clients should use. Without being able to set this, the DHCP settings provided by the router specify the router address as the DNS server. Why does this matter? If you are using tools like Pi-Hole all traffic is shown to come from the router. This does not allow you to identify which host is making DNS requests. You can manually update the DNS server(s) the clients are using, but this should be a configuration setting within the router configuration. https://community.netgear.com/t5/General-WiFi-Routers/R7900-DNS-Configuration/m-p/1648068#M712082.9KViews6likes1CommentOrbi add dynamic DNS support for Google Domains
I upgraded from another router that had the option to use Google Domains as my dynamic DNS provider. Since the Orbi only has Netgear, Dyn, and No-IP i will need to run an updater on my computer. I twould be a nice feature to add to the platform in the future. https://support.google.com/domains/answer/6147083?hl=en9.7KViews16likes11Comments
