Daisy Chain
1 TopicGS105PE PoE Daisy Chain
Hi, I need (or rather want :smileyvery-happy:) to install two switches in a place where there is no power. My existing network consists of an ASUS WiFi Router and not much else. My plan is as follows: Run power + data via a PoE+ Injector to the first GS105PE Run the second GS105PE off of PoE Passthrough from the first GS105PE Only run data (no power) from the rest of the available ports (PoE only needed to power the switches themselves). I hope this mockup will explain my theory: Will this work? Thanks in advance.Solved
