Dropping Connection
1 TopicN450 CG3000Dv2 dropping wired and wireless connection repeatedly
A few days ago I started losing my connection from my N450 CG3000Dv2 modem/router. This occurs on both a hard-wired (gigabit) connection to the router and on other devices connected wirelessly. I contacted Comcast support the first time this happened and they sent refresh signals to the router (which hasn't helped). On the next call to Comcast, they said everything looked good on their end and that I'd need to contact Netgear. Is there any diagnostic I can run locally in order to determine if the router itself is failing? It's not quite 3 years old, but I've had routers before that dropped connections like this and I'm not sure if they lasted more than 3 years either. thanks, Matt4.5KViews0likes7Comments
