Firmware Update
2 TopicsVPN Setting
I'd like to see VPN Setting update in next firmware update that allows users to setup VPN with other VPN clients. While current instructions do allow for Smart DNS and shows how to create a VPN connection, it lacks today's needs. Having VPN support setting eliminates the need to run VPN on each device by allowing all connections to flow through router as one connection. Most services limit up to 3 connections at once. Having this support on my R8500 would totally eliminate the connections limit. Please consider supporting this with next firmware!24KViews15likes2CommentsRate limit by MB's for Netgear WC9500
Dear Netgear, I'm struggeling with rate limits which I would like to configure on a Wifi network which is currently installed at one of our clients. We're using a Netgear WC9500 in combination with Netgear WNDAP360 AP's. I've configured multiple SSID's, one of them is for guests. I would like to limit this SSID by MB usage instead of a percentage of the bandwith. This way I can prevent guests from hijacking the entire Internet connection. please consider this feauture in the next firmware. regards, Frank14KViews2likes1Comment
