Firmware
2 TopicsWAX638E Truncates MPSK Table
We have around 30 APs, about 24 of them WAX638Es, and the rest 620s, with one 610Y. We've deployed MPSK on a network, with 43 key entries. Currently, the full table copies to the 620s and 610Y, and users can instantly authenticate as expected. The 638Es, however, only copy in the first 8 entries, whether they are on PoE+, PoE++, regardless of switching config, and the issue persists after both an insight remove/re-add and a factory reset and re-add. I have an open case on this issue, started two days ago, but I wanted to post it here for posterity. Jonah83Views0likes1CommentA Message to Insight 2.x customers from the NETGEAR Insight Team!
Hi Everyone, Greetings from NETGEAR. As a follow up to our earlier communication regarding upgrading from Insight 2.0/2.x to our new remote access, cloud-based Insight solution, we want to remind you that at the end of this year we’ll be ending support for Insight 2.0/2.x. We encourage you to upgrade to Insight 3.1 - our new cloud-based Insight - as soon as possible. Migrating will give you the opportunity to enjoy the many advantages of the Insight cloud platform as well as the features in Insight 3.1 managing a broader range of devices – access points, switches, and storage. Here are links to the Apple App Store and Google Play store to upgrade. Apple iOS Google Android As the year comes to a close, we want to take the opportunity to thank you for continuing support for NETGEAR and to wish you the very best for 2018. Thank you, The NETGEAR Insight Team What do I need to know about the transition to Insight 3.0?2.4KViews0likes0Comments
