lakewood_it's avatar
lakewood_it
WAX638E Truncates MPSK Table
We have around 30 APs, about 24 of them WAX638Es, and the rest 620s, with one 610Y.
We've deployed MPSK on a network, with 43 key entries. Currently, the full table copies to the 620s and 610Y, and users can instantly authenticate as expected.
The 638Es, however, only copy in the first 8 entries, whether they are on PoE+, PoE++, regardless of switching config, and the issue persists after both an insight remove/re-add and a factory reset and re-add.
I have an open case on this issue, started two days ago, but I wanted to post it here for posterity.
Jonah
1 Reply
  • To clarify - this is not an issue of the 638E only displaying the first 8 entries - it actually does not have them at all, as the 9th through 43rd user in the key list cannot connect. All 638s are on 12.8.0.6, except for one on 10.8.10.10, which is also affected.
ProSupport for Business
