Help
1 TopicLAG setup JGS524Ev2 and GS752TS kills network
Hi, I am attempting to create a 2 Wire LAG between a JGS524Ev2 and a GS752TS I am using ports 1 and 2 on each switch. I have created a LAG group for ports 1 and 2 on each switch. The JGS524Ev2 is in one room whilst the the GS752TS is in another. I have ensured there is no extra connection between the two switches other than the 2 Wire LAG. The JGS524Ev2 has a laptop and a couple of NAS connected. The GS752TS has 2 DNS servers, an NTP server, a Wireless Access Point and a pfSense Router connected. Before I connect the LAG cables I check communication with a single wire in Port 5 on each of the 2 switches. Everything connects, talks and works fine. I disconnect the cable in Port 5 and connect the 2 wires of the LAG at which point the Wireless Access Point goes berserk, turning itself on and off, the pfSense Router ceases to function as do the DNS and the NTP servers. Yet the laptop still functions and I can call up the GUIs for the 2 switches, which tell me they are transmitting at 1000MB. I am obviously doing something wrong, but followed the NetGear guides that I could find. Can anyone give me some advice please, such as unplug all ports, establish the LAG then replug the devices etc. Or any other strategy that let's everything work. Sometimes the NetGear guides are a bit nebulous... Thanks and kind regards, jBSolved3.1KViews0likes3Comments
