Help
2 TopicsCan't Find - VPN Client license key lost for SRX5308
Purchased the firewall in November 2015 and just now need to use the VPN features. Unfortunately, I cannot locate the original five VPN Client software. Can you provide me the license key so that I can activate the VPN Client software? Device is registered in my account so you can see the serial from there.Solved5.9KViews0likes8Comments
