Inactive Volumes
5 TopicsReadyNAS 314 - inactive volumes error.
Hello Netgear Community, So I'm a NAS noob and my home "ReadyNAS 314" has decided to greet me with the following error message. "Remove inactive volumes to use the disk. Disk #1,2,3,4." It's a 4 bay NAS with WD Red 4tb drives in each slot set to RAID5. I've done a fair bit of Googling which led me here. Is there a way for me to get this thing going again or am I potentially out of luck and have lost everything? Thank you.Solved356Views0likes2CommentsReadyNAS 4312 | inactive Volumes
Hello! I am unable to access the drives / data on my Netgear ReadyNAS with 12 drives in RAID6 configuration with the following error in the UI: Initial Error observed in log: Volume: The volume data encountered an error and was made read-only. It is recommended to backup your data. we have rebooted the NAS. then it is showing the below error. Remove inactive volumes to use the disk. Disk# 1,2,3,4,5,6,7,8,9,10,11,12. and we check in logs after a disk test: Warning in logs: Volume: Disk test failed on disk in channel 10, model WDC_WD101KFBX-68R56N0, serial 1DGPMKDZ.400Views1like3CommentsRAEDYNas 104 inactive Volumes
Hi, I had not accessed my NAS for several days I tried to upload some data but my MAC couldn't find the volume? I couldn't log in to admin and checking the front panel it just said DEAD I rebooted and all looked like it came up OK but the volume was still missing, in admin I now have a Data-0 which appears to be my Volume and Data which is 0 in size. The error message says 'Remove inactive volumes to use disk, Disk #1,2,3,4 How can I recover the data volumes I bought a backup several days ago but with the size of data and the fact that it's on Raid5 I haven't had chance to run it. Please help as there are several years of photos as well as development data on there that I need to recover.134Views0likes2CommentsRemove inactive volumes to use the disk. Disk 1,2,3.
Hi, My Disk 1 of 3 was degraded (4 TB Western Digital Red - made for NAS drives). After defrag and balancing to no avail - after a short while (an hour or two) the web inteface was unreahable, however the disk was available in filesharing. After that I did a reboot and then I got the message where the webinterface was ok again but "remove inactive disk 1,2,3" They disks are now all unmounted and red on the web-interface (green light, though). What should I do? BR JakobNEW: v6.6.1 = No Apps, and Inactive Volumes
Good Evening Community and NETGEAR Staff - Needless to say at the moment, I am very frustrated; the ONLY thing that consoles me, is that it seems that I am in NO WAY the ONLY person experiencing issues [ I ALWAYS hate doing updates and this proves me right ]... By now this is not anything NEW - my problems start w/ Inactive Volumes, which leads to ALL of MY DATA suddenly *poof* = GONE; which of course explains why there are NO Apps ( PlexMedia, SickRage, VPN, etc... ) nor do I have the ability to ADD any new ones. After the update ( yesterday ) - everything appeared to come up as expected / normal - it wasnt until today when I was attempting to use PlexMedia that I noticed that the system was none responsive, I also attempted to access my shared network drives and saw that it too wasnt working - as I have in the past I decided to reboot the NAS and get it back ONLINE -little did I know that I was signing my own death certificate. After taking a while to shutdown, waiting for a bit and then cold booting the device - I learned that the system is hosed ( honestly I am hoping that its a buggy OS and that everything is safely in there somewhere otherwise WTF! -apologize but honestly frustration is kicking in )... Looking through the logs, ( like many others ) I too see errors about some files affected with a virus which is funny since the anti-virus app was none responsive after the upgrade ( yes I was prepaired for that, after getting the e-mail informing me - however wasnt that supposed to have occured back in the beggining of Jan' 2017 -here we are in Feb a little back dated or delayed -No? -I figured by now it would've been safe to go back into the water -Never learn ). So like everyone else I will do my best to be patient, and if I wind up having to pay for support - then it better come w/ a Guarantee that they will Recover what has clearly been corrupt by a buggy update.
