Insight Web Portal
68 TopicsPR60X Resource usage for CPU and RAM
It would be helpful if the PR60X monitoring interface(s) included resource usage for CPU and RAM. For both the web based UI and Insight App/Portal it could be included on the Dashboard along with internal temperature and fan speed. The use of color (as with internal temperature) would improve visual recognition of condition. SMB and MSP customers with extensive SNMP deployments might find these values useful in a MIB.40Views1like0CommentsAbility to schedule Firmware updates to multiple devices at the same time needed
Wanting the ability to schedule switch firmware updates for all devices via the Insight Portal. Currently, we can only schedule on a per-switch basis. You can reschedule recurring reboots, but it would be very help for customers who a lot of devices. We have close to 300 switches on the portal. It is not very effective to have to go into every device to schedule the firmware update. Thx13Views0likes0CommentsAdd the field "Port Description" to the hover over display on the Insight Switch Summary page
Please can you add the field "Port Description" to the hover over display on the Netgear Insight Switch Summary page. When you want to map and record what device or patch port is connected to each port, its slow to have to go into the properties for each port, its best in the hover over button please.100Views0likes4CommentsInsight Menu Improvement
Please add a way on insight to see the device menu the same as the Local UI. It is frustrating to be comfortable in the local user interface and not be able to find a setting. DOS (denial of service) freaked out and shut down all of my ports. I had access to Insight but could not find any way to shut it down. If a security issue require a MFA prior to making the change. Search boxes? Mine do not work. It would be amazing to type DOS and have it take me to the menu for it. List of common settings for most devices that are factory preset, so you don't have to search for it and you know what it is set to.19Views0likes0CommentsSet up mesh on WAX 628 without need for insight subscription
Feature request On wax 628 after 4 year subscription ends we should be able to amend mesh mode as currently it can only be done via insight. So after 4 years if you had to factory set the ap for what ever reason what you are saying is i have to pay subscription fee to have access to a basic setting which should be accessible regardless because this setting is a bare necessity for having multiple ap's and the main reason to have bought these pieces of equipment. You should not be held ransom for access to this basic necessity. This feature should be added to the next firmware update like for example accessing it via device ip address configurations Currently to be able to mesh multiple ap's you have to go to mesh topology on the insight app to change mesh mode to auto, root , extender or disable. After 4 years if this stays the same I have to subscribe per unit to be able to have access to this basic setting which is utterly ridiculous if you think about it. If you were to factory reset or for whatever reason need to change the mesh mode you couldn't without ponying up. So after 4 years my equipment is redundant because it wouldn't serve me the purpose for which they were bought for. So this should be added and available to access in the device IP access configuration page via local network79Views0likes1CommentInsight Captive Portal (Free)
You have added a much-improved Captive Portal option to Insight, but have failed to provide any option to retrieve the collected data, i.e. name, email, etc. I spent the time and went through and set it up only to subsequently spend hours trawling through the whole portal in detail and ultimately contacting support to discover that this "may be an option in a future release", which makes the whole thing pointless and a waste of time. I suggest that you at least make a note on the portal to state that the feature is incomplete, although it would be far preferable to provide access to the data collected!50Views2likes0CommentsEasier to assign device credits
We recently had to apply device credits for the first time and were unable to locate the way to do it in the Premium version. After working with Support (Thanks Dennis H.) He informed me on where the "Managed" toggle switch was under devices and we then had to scroll to the side to find it. I would like to see the toggle to be closer to the Credit Status. This way it is easy to see and activate when needed, for those that may only need to access this section a once or twice a year. Thanks and happy computing.265Views1like0Comments
