M4300-12X12F
2 TopicsM4350-12X12F SNMP v3 traps configuration
How to configure SNMP v3 Traps on this switch? I have current snmp config: snmp-server sysname "CENSORED-SYSNAME" ! snmp-server user "zabbix-netgear" DefaultWrite auth-sha512-key CENSORED-AUTHKEY priv-aes128-key CENSORED-ENCKEY snmp-server password-strength snmp-server v3-host CENSORED-IP "zabbix-netgear" traps priv acl-trapflags snmp-server enable traps captive-portal snmp-server enable traps mac-notification change ip dvmrp trapflags ip pim-trapflags However snmptrapd says that this user has authentication failure, here is part of the config createUser -e SWITCH_ENGINE_ID zabbix-netgear SHA "CENSORED-AUTHKEY" AES "CENSORED-ENCKEY" Despite having correct engine ID, correct keys switch cannot properly authenticate? I think problem lays in switch itself because sending test trap using snmptrap with same engine ID, auth key and encryption key works fine. Firmware 14.0.4.14193Views0likes1CommentCan't ping hosts across SFP+ and RJ45 ports
I've recently bought a M4300-12X12F switch, which has 12 RJ45 ports and 12 SFP+ ports. I have some computers connected via RJ45 ports within the network, let's say 10.155.129.x/24 And now I have a computer connected via SFP+ ports, also in the same network (10.155.129.x/24) But my problem is, hosts with RJ45 can't ping that host with SFP+ or the other way around. I have no idea why. Can someone help me please?5.6KViews0likes10Comments
