MR1100
36 TopicsImproving Mobile Gaming Performance When Using a 4G/5G Hotspot
I've been using mobile hotspots for gaming and noticed that connection stability can sometimes matter more than raw download speed. For online games, consistent latency and avoiding sudden drops are particularly important, especially when several devices are connected to the same hotspot. I'm curious what settings other AirCard users have found most useful for gaming. Do you normally use 5 GHz Wi-Fi, USB tethering, or another setup to get the most stable connection? Are there particular NETGEAR AirCard settings that you've found helpful for reducing latency or maintaining a stable connection during longer gaming sessions?Nighthawk MR1100-100 Cannot Access Settings
Hi, I am based in the UK and trying to use a 3 SIM card. I can connect to the device and it detects that it is a 3 sim but get a message saying "no internet" and a message on the Nighthawk screen states APN set up required. I get directed to the set up page using the IP address for the router or m1login.net but the unit will not accept the admin password. I have tried using the admin password printed on the label under the battery, have used "admin" and "password" none of which work. I have conducted a factory reset of the unit and still the same result. This happens whether I use my Android phone, MacBook etc. I believe I need to change the network provider setting but have spent 3 days going round in circles. Please help! :) Thank you in advance for any assistanceNighthawk mobile router roaming
I have a nighthawk M1 mobile router which I’ve using without problems in my home country (UK). However I am currently in France on holiday with on overseas data plan from EE and the router when switched on says Roaming Data Disabled and never gets beyond the orange flashing lights. ive opened the Netgear Mobile app but it can’t find the router and won’t accept “admin” and “password” to login, nor does it offer me a “forgotten password” option to reset it. i then try to access settings via the https route but that tells you log in via the app which I’ve already tried and failed. ive seen lots of chats online about possible fixes but I haven’t found one that works yet - very frustrating. Would really appreciate some good adviceM1 Upgrade ?
Today, I bought a Nighthawk dual band router WIFI 7, thinking it was an upgrade on my old Nighthawk M1 which acts as a modem and router. I have now unplugged the Nighthawk 7, as I found, that to make it work, I needed to plug it into the old MI, that I was trying to replace. I am older and wiser now. I think I was taken for a ride. I thought it was an upgrade on the old M1. It isn't. It's an add on at best. You have just sold me your last product.can not see my net worth on my M6 Pro
I have been using my MR1100 for a long time with no problems but I was told the M6 Pro is much better. So I got one. I connected it to my desktop,phone and TV But When I search for my net worth on my dell lap top it is not there ? It did work when I was using the MR1100. I need this to work because I use the lap top when we are in the motorhome. PhilSolid purple screen on the display with no text and solid purple and purple border lights
Hi there, I am having the same issue with my M1 now. Having changed nothing, I now get a solid purple screen on the display with no text and solid purple and purple border lights. Although the internet is still working (blue light flashing) - I guess it is just a display issue now. Things I have tried: removed SIM and put back in - same issue factory reset - same issue on restart changing SIM in the M1 - new sim works ok (normal display), but when return to my normal sim, same issue tried my normal SIM in my phone to check it works - it works, so no issue with my normal SIM it seems Any suggestions to resolve this? Many thanksI recently got a Netgear Nighthawk M1 (Model: MR1100-1TLAUS - Telstra)
Hi everyone, I recently got a Netgear Nighthawk M1 (Model: MR1100-1TLAUS - Telstra) from a friend. I am looking for a solution to manually update the firmware, as the OTA function is not picking up the latest version. Device Details: Current Firmware: NTG9X50C_10.25.01.00 Netgear Initial Firmware: NTG9X50C_10.25.01.01 Target Firmware: I want to upgrade to the latest version NTG9x50C_12.06.08.00. The Issue: Since I cannot update via the WebUI My Question: Has anyone successfully updated a Telstra unit from version 10.25.01.00 directly to 12.06.08.00? I have tried manually updated via WebUI but it showed error 16 Any guidance on the correct procedure to force this update would be greatly appreciated. Thanks!Settings - setup - Mobile Router Setup ... turn off wifi tethering is not marked
Hi all. "Settings - setup - Mobile Router Setup ... turn off wifi tethering is not marked" turned out to be my problem even though it's not the solution to the Original Poster's problem. I have no idea how that setting was ever changed. The only thing I remember doing was replacing the router's battery (after which the router stopped being detectable by nearby devices such as my phone). Thanks Ksa3344 who suggested this. It saved me a lot of grief.
