Managed Switch
10 TopicsAV line M4250-9G1F can any port become a trunk port?
Hi. Can I configure my M4250-9G1F so that every port acts like a trunk? I have a M4250-26G4F-POE+ as my main switch and have a fiber connection to my M4250-9G1F. From there I would like to use 6 ports to connect 6 more M4250-9G1F in a star typology. All using dante and control. Is this possible? Looking forward to you thoughts.3.4KViews0likes0CommentsLimit bandwidth on port - confused
Hi I have a guest house and I've created a vlan for the guests there, using only port number 24. I'd like to limit the bandwidth from that port to 100 Mbps but get confused by instructions in the manual and in the web interface. At one place it says I should define the "Interface Shaping Rate" to a number between 16–16384 (manual) and at the other is says between 1-100 (the web interface). I'm doing something wrong. Can you help me out here?Need to limit bandwidth (rate) by port
I need a switch where I can set limit rate or bandwidth by port. Here is the situation. My church streams and we currently have a 10Mbps down and 1.1Mbps up. If there is a few people are on the network (WiFi), then the sustained streaming rate is fine with no caching or drop outs but get 60-100 devices hanging off the wifi. If ever all will decide that now is a good time to download updates or something else, then the stream is shot to... I am thinking that if I can limit the rate through the ports I connect the WiFi devices to, this will limit how much of my "pipe" is used so I can keep the 1.1 Mbps upload untouched. Or if there is a way I can dedicate that much bandwidth always for upload only that would work to.4.1KViews0likes0CommentsNo Internet After Connecting GS808E Switch to Router
I have spent too many hours resetting things to default, trying to reconfigure things, plugging and unplugging cables, etc. Whilst I have multiple devices in the house, all the PC's in the house are on Windows 10, not that it should matter. Here is my list of components in my home network: Modem: Netgear CM600 Cable Modem (service provided by Spectrum) Router: Asus RT-AC3200 Switch: Netgear GS808E (Nighthawk S8000) Brief history: PC connected directly to modem, works/have internet connection. Router connected to modem/PC connected to router, works both wired and wireless. Introduced the Nighthawk S8000 (or either of the other two switches I have at home), no internet anywhere. I assumed that adding a switch to the mix, to expand my network would be fairly easy/plug and play. A crappy TrendNET 5-port switch worked previously, when I had AT&T Uverse, and some ports worked on the crappy 8-port Monoprice switch that I had. Yes, modem is connected to WAN port on router. Yes, port 1 on router is connected to port 8 on switch. I have enabled jumbo frame on the router under "Switch Control" as well. I have tried rebooting and resetting things. I have tried powering up the router first, then the switch, and tried powering up the switch, and then the routerClick Switch for Google Wifi mesh backhaul not working
Hi ! Bottom line, my Google WiFi access points are not able to properly see each other on the ethernet and Google suggests it may be my switch configuration's support for SPT... Network layout is rather simple home office setup. - I've got a cable modem. - Connected to my main Google Wifi unit (as per Google's requirements, I would have preferred to connect the cable modem directly to the switch) - Connected to a NETGEAR Click Switch (GSS108E) - On that switch, I have a couple of computers, 2 Tivo boxes, a printer, and 1 addtional wired google WiFi unit. - There are no VLANS. Just a flat /24 IP space as defaulted by Google (192.168.86.1 - .255) - The main Google WiFi unit is providing DHCP services to everything, and I can ping all connected devices and tracert with a single hop. Thanks for your help !4.3KViews0likes0CommentsProSafe GS752TP - firmware upgrade procedure
Hi, Can someone please explain the step-by-step process on how to upgrade a ProSAFE GS752TP firmware? The current software version of my switch is running is 6.0.1.16 - I believe this is already the highest version. However, I'm doing this strictly for learning purposes. I've upgraded smaller "home office" switches by simply downloading the firmware and pushing it through a TFTP utility (or some switches have a built in utility) so I understand the concept of what I'm doing. I'm not having any luck using the TFTP utility, or the built in utility on my switch - which leads me to believe that I'm doing something wrong. So if someone could outline the process (with links, applications, etc...) that I'll need to perform the upgrade, I'd really appreciate it. I've looked up articles, read the manual, downloaded the how-to however I can't find simple step by step. Have a good day !4KViews0likes0CommentsNew GS308 switch will not give internet and assigns a weird ip. is this for internet or just network
The new GS308 switch will not give internet access and assigns a weird IP address. Is this for internet or just network PC? The purpose of the switch is to give more ports to connect more devices to the Internet right? I connected a new GS308 from working NETGEAR WiFi router to switch then the device to the switch and there is no internet. I cannot see the switch connected to the network and the switch gives out a weird IP address to the device. There are no labels on the ports of the switch so I guess I can use any port to connect to the switch (I tried the 1st port). Am I connecting it wrong? My set up works fine without the switch.3.6KViews0likes0CommentsManaged vs Unmanaged Switch - What is a Managed switch? #Learn
NETGEAR offers a multitude of network switches to suit a wide variety of consumer and business needs. This is split into several broad categories that revolving around the ""management type"". Switch management type defines how a network switch handles traffic two and from its various ports. Switches can either act without questioning any traffic they are as an ""unmanaged switch"" that can only work with the configuration they were shipped with. As featured are needed or desired by the network architecture, switches become managed switches. Managed Switches are more flexible, and the configuration and priority of traffic can be adjusted in various ways by ether adjusting settings on the switch directly, or by logging into the switch's configuration pages or in the case of NETGEAR Insight Switches - directly through a cloud Management app. We want to help you to pick the right switches for your business and home. We have switches with management and capabilities for any level of expertise or business requirements. Please read on to help you find what kind of NETGEAR Switch is right for your next deployment. We'd love to hear your feedback so we can further refine and clarify the concepts in this article. Unmanaged Switch: Unmanaged switches are easy to set up and offer simple connectivity with no need for management - perfect for most home office deployments. Unmanaged switches are sometimes incorrectly called an ethernet splitter vs switch, but they are different since even unmanaged switches don’t reduce traffic on every port in order to split a signal. With an unmanaged switch just pick the speed and number of ports that you want, plug it in, and connect your devices. Unmanaged switches are available in speeds of Fast (100Mbps) or Gigabit Ethernet (1000mbs). Recent developments have even unlocked the potential of 2.5gbs, 5gbs, and 10gbs with Mulit-Gigabit Unmanaged Switches. There are also models that support Power over Ethernet (PoE) allowing you to power devices like PoE security Cameras, IP phones and even LED lighting. Often the cost of a small unmanaged PoE Switch is comparable to the cost of a PoE Injector. To view NETGEAR’s entire line of Unmanaged Switches visit our Unmanaged Switches landing page. Visit the Unmanaged Switches Community for more feedback and discussion. Smart Managed Plus. Smart Managed Plus switches offer Quality of Service (QoS), virtual local area networks (VLANs), and network traffic monitoring at a small premium over unmanaged switches. You can login and manage them right from your web browser—no software required. These switches are ideal for the home or small office that needs basic network management features and PoE capability. Smart Managed Plus switches are available in speeds of up to 10 Gigabit Ethernet. To view and learn about NETGEAR’s line of Smart Managed Plus Switches from the NETGEAR Smart Managed Plus Switches landing page. For discussion and feedback visit the Plus / Click / Smart Switches forum. Smart Managed Pro. What is a Smart Managed Pro switch? Smart Managed Pro switches provide the same features as Smart Managed Plus switches, but with many more options for access security (RADIUS), traffic control (ACLs), static routing, monitoring (SNMP), and cable testing. The Smart Managed Pro line of switches is a big step up from Smart Managed Plus and is intended for commercial use. Smart Managed Pro switches are the perfect fit for small to medium organizations of up to 200 users, possibly with a network core composed of Fully Managed Switches. Visit NETGEAR’s line of Smart Managed Pro Switches landing page. For discussion and feedback visit the Plus / Click / Smart Switches forum. Insight Managed Smart Cloud Switches. Insight Managed switches take networking to a new level, with unified, policy-based architecture rather than individual, device-by-device setup and management. Insight Managed Smart Cloud switches also provide remote cloud management and monitoring, and advanced L2/L2+ switching features such as VLANs, ACLs, QoS, LAGs, and Multicast, building on NETGEAR’s powerful Smart Managed Pro switching line. More importantly, Insight Managed switches and access points support auto-join and configure (zero-touch provisioning), as well as a single-pane-of-glass view for managing all of your Insight Managed networking devices, and multiple network locations anytime, anywhere, using the NETGEAR Insight mobile app. The Insight mobile app offers easy device discovery, one-touch registration, simplified setup, configurable alerts and notifications, and ongoing firmware management for Insight Managed devices. Network administrators can manage an entire network of Insight Managed devices with a single administrator password and real-time cloud monitoring. The Insight Cloud Portal (available to Insight Premium subscribers only) offers the same great features as the mobile app as well as highly customizable monitoring options. We even offer Insight Pro for enterprise, MSP’s and VARS. Click to view NETGEAR’s line of Insight Managed Smart Cloud Switches. For more discussion and feedback visit the Insight Managed Smart Cloud Switches forum. Click and Easy-Mount Switches. NETGEAR Click Switches and Easy-Mount Switches offer innovative mounting options that let you deploy them where you need them—vertically, horizontally, under a table or desktop, on a pole or desk leg, or on a wall. NETGEAR offers several models of Smart Managed Plus Click Switches. Their small, sleek form factor and silent operation make them ideal for a small or home office or for edge deployment in an enterprise network. In addition to mounting with their Virtually Anywhere™ mounting system, you can also rack mount Easy-Mount Switches. NETGEAR’s Easy-Mount Switches come in both Smart Managed Plus and Smart Managed Pro versions. Visit here to view NETGEAR’s line of Click and Easy-Mount Switches. For discussion and feedback visit the Plus / Click / Smart Switches forum. What is a Fully Managed Switch? Fully Managed switches offer all the features of Smart Managed Plus switches with additional Layer2 (switching) and Layer 3 (routing) functionality. Advanced Layer 2 features include granular traffic shaping (using ACLs) and scalable deployment options (using L2/L3 DHCP relay agents). Network Access Control offers tiered authentication with 802.1x defaulting on MAB defaulting on captive portal. Advanced Layer 3 features include resilient and load-balanced static routing (all series) or dynamic routing (RIP, VRRP, OSPF, PIM available in some series). Fully Managed switches also provide a command line interface (CLI) that lets network administrators easily configure and deploy these switches in wide-scale enterprise environments. Fully Managed switches most often serve medium-sized networks. NETGEAR’s M4300 series switches are also preconfigured for AV over IP deployments, transmitting zero latency uncompressed UHD video. Go here to view NETGEAR’s line of Fully Managed Switches. For discussion and feedback visit the Managed Switches forum. Gaming and Media Streaming Switch. NETGEAR currently offers 2 smart-managed switches for gamers. The SX10 and the S8000 Switch. These switches both come with striking looks with LED lighting and customizations to allow you to prioritize the traffic to your gaming and streaming PC, gaming consoles or PLEX NAS Storage server. The both Nighthawk Gaming & Streaming Switches offer low latency, port prioritization, and Quality of Service (QoS) as well as user-friendly configuration and built-in presets for gaming and media streaming. The Nighthawk Switch is ideal for multi-user gaming and 4K UHD media streaming in a household full of Internet-capable devices. The SX10 includes customizable RGB LED Lighting and 2x Multi-Gig ports allowing up to 10gbs ethernet. For more information about the Nighthawk S8000 Gaming & Streaming Switch and the Nighthawk Pro Gaming SX10 Multi-gig Ethernet Switch. Visit our NIGHTHAWK Pro Gaming Switches Forum for feedback and discussion. For help narrowing your options, you can also use NETGEAR’s Switch Selector to view models by number of ports, link speed, management type, mounting type, and several other options and features. Find the right Switch for you - visit the NETGEAR Switch Selector. This article references KB article 25445 - Which-NETGEAR-switch-is-right-for-me - Please references it for additional information and updates. We hope this post had valuable content and thanks for your feedback!3.4KViews0likes0CommentsDevice view Java plugin fungerar inte
För närvarande har jag installerat två Netgear Managed switchar: M5300-52G3 och GSM7248V2. Jag kan inte se switch-diagrammet på sidan Device view. Det står "Du behöver Java plugin. Hämta det här" men "här" tar mig till Oracle Java-nedladdningar, och tar mig inte till den uppdatering jag behöver. Jag har installerat Java 8 uppdatering 65, men problemet kvarstår. Jag har provat med flera olika webbläsare och det blir likadant på alla.Hur man kontrollerar problem på switchen?
Jag skulle vilja veta hur man kontrollerar sin switch för att se om den har problem. Jag felsöker ett företags Gmail-problem, och tror att det är ett eventuellt problem i nätverket. Jag har ett enkelt nätverk och switchen är näst på tur för att kontrolleras. Någon feedback skulle uppskattas. Tack.
