No IP Address
3 TopicsWhen shutting down or upgrading firmware my RN214 will not sutdown all the way. I get a do_exit+9ec
When trying to shutdown my ReadyNAS 214 it hangs with an error of do_exit+9ec on display. The only way to recover is to disconnect the AC power cord and reconnect. I have the most current version of firmware Version 6.9.3. Same error occurs regardless of how it is done. Occurs when shutting down from the power button or from the system device webpage. Any suggestions? Had a similar problem when I first purchased this unit and during upgrades and shut downs. The NIC lights do not light up when this problem occurs. I am directly connected to 1gb router. The network settings on the RN214 was set to DHCP with the GB Router reserving a specific IP for the RN214 prior to the firmware upgrade - system was working, had network connection. Before upgrading to 6.9.3 I changed the Network on the RN214 to Static. After the firmware ugrade and rebooting I got the do_exit+9ec error. I did this thinking the dhcp option was causing a problem. Any help to get me back on line would be greatly appreciated. Please advise. Thank you.3.2KViews0likes12Comments"No IP Address" after Firmware update
I logged on to readycloud yesterday and it suggested updating the firmware. I clicked "OK", the update seemed to go through fine, but now I cannot find my device on the network and it flashes "No IP Address". I have tried rebooting multiple times and even did a factory reset. Any advice would be appreciated -- we are a small nonprofit and cannot afford expensive support packages. Thank you, Phoebe3.5KViews0likes3CommentsReadyNAS 204 shows "No IP Address"
The unit shows "no IP Adress" even though the ethernet port shows activity and the router show connection.. When I initially tried to shut the unit down it said that it was shutting down and "Goodbye" but did not shut down. It looked like it displayed an instruction something like exit800. I pulled the plug and rebooted. Still no IP address. I used the boot option to reload the firmware; which it did but still shows no IP address. Any suggestions on where to go from here? The unit will still not shut down properly.12KViews0likes17Comments
