No WiFi
6 TopicsCannot access router on CG3000DV2D despite having a wired connection to internet
I'm unable to get (the previously working) wifi running on my four month old CG3000Dv2 modem/router despite countless hard resets and then turning on and off the wifi button on the unit. Wifi oony gets a self-assigned IP address. Also cannot access the router at 192.168.0.1 nor at the address appearing in my (Mac) network preferences, which is 173.23.168.1. Ping results at 192.168.0.1 and 192.168.1.1, as well as the router IP are unssucessful. Yet, a wired connection works. Any help is greatly appreciated.Solved1.6KViews0likes4CommentsOrbi AC3000 drops internet EVERY NIGHT
First off, we have the Netgear Nighthawk Docsis 3.0 Cable Modem Router (with the WIFI disabled) running a wired connection to our Orbi- and we have 2 sattelites. Every Single Night the wifi drops around 9:30pm. Every. Single. Night. The wired connection from the Nighthawk is still working though- I can use our desktop computer. Just no wifi capabilities in our home. Which leads me to believe it's an Orbi thing. Why is this happening and what do I need to do?Updated Orbi Router Firmware - now lost WAN access?
I received a banner notification in Orbi App this morning saying new firmware was available so I clicked on the "Update Now" button. It downloaded and installed the firmware, then rebooted. When it came back online I have LAN access and all of my devices are connected but no internet access now (WAN) ?? I unplugged cable modem and Orbi router for 60 secs and plugged cable modem in. After 2-3 mins when cable modem came online I plugged Orbi router back in and waited 2-3 mins for it to come online. No change. All devices connected but still cannot connect to internet??SolvedN600 Router Model C3700 - Power on, All Lights Flash Periodically, No Internet, No WiFi
C3700|N600 Cable modem wifi router. 1.y years old. It suddenly stopped working. When switched on power light is getting on (green) and nothing happens then after a while (may be 30 secs) all the lights flash and goes off then power stays on. The router stays on like this (periodic flashing of all the lights). In this state the router is not accessible with either by network cable nor by WiFi and there is no internet connectivity as well. This problem was occuring once in a while and then it got resolved automatically i.e. if you switch it off and leave it like that for hours and switch it on then some time it worked earlies. But now it stopped working completely and it exhibits the above mentioend behavior consistently and not going back to the working state. Whether it indicates the firmware got corrupted and it need to be reinstalled. If yes how to do that? Factory reset and power cycle did not help. The behavior remains the same (i.e. power on, periodic flashing of all the lights but no internet, no WiFi and no connectivity to the modem/router).6.7KViews0likes1Comment
