No power
4 TopicsReadyNAS Duo. Today wont power on (was shutdown fine via Frontview) - options please?
Dear all As well as having the flu I am crying at the NAS. I have an ReadyNAS Duo v1 from about 2012 ish I guess. It has 2 x 2TB drives at about 65 percent full. My Zigor UPS died yesterday. So i have binned that. I moved the ReadyNAS plug to another socket and it was fine. All worked well. This morning I had to remove the UPS so I shut the office down, and shut the NAS via front view. All well. Replugged everything and now it will not start. I have tried a different plug and have ordered a new 12v PSU from AMazon and I really hope it works as like you all my life is on there. So my questions are please? 1) has this ever happened to any of you and will the new PSU fix it 2) if it doesnt do you know what I can do other than buy the same one again put the drives in (but I am guessing it will sync and delete 3) any idea how I can resuce the drives and data please of it will not turn on? 4) say its all dead - whats the best option for replacing... I do not stream from it its just storage but I liked the redundancy of the drives. Do I just use cloud? 5) any help gratefully received. Thank you C2.7KViews0likes5CommentsReadNAS NV+ v3 will not power
Please help. Two nights ago our ReadyNAS was powered down normally to move to a different location. Nothing out of the oridinary happened. There is no hot or burned smell from the unit, but now it is compeltely unresponsive when attempting to power on. A second power cable was tried in a known-good second outlet as well, still no fan spin-up, no lights, nothing. I suppose it could be time to upgrade the unit which I'd actually been research (of course), but there is a significant amount of new data needed since the last full back up. ser#23J3027A00890 It is v3 (not v2) - MODEL 4210-100NASSolved3.7KViews0likes6CommentsReadyNAS RND4210 wont power up
I have an older RND4210 (circa 2008) and we had a nasty storm this weekend, lost power for about 16 hours and now it wont power back up. Not sure what my options are? Thinking up upgrading to a new ReadyNAS but not sure how I go about getting the data from the old one to the new one? Thinking of getting a ReadyNAS RN20423D.2.9KViews0likes3Comments
