Power Supply
14 TopicsReadyNAS 626X spare power supply
This is a request for information: where I might buy a spare replacement power supply for my 626X. My ReadyNAS just went out of warranty and I am late getting this done. I want to buy a new power supply for the NAS for that inevitable day when the PS dies. Currently its working fine, but I want to avoid waking up to a dead NAS and having to scramble to replace a dead power supply. I don't know what power supply will work. From the documentation a 200W power supply is installed, and I suppose I'll have to open the box to see exactly what model is installed. TIA for any tips! DavidSolved304Views0likes6CommentsReadyNas NV+ Post New Power Supply Boot Issue
Recently my ReadNAS NV+ stopped working after almost 8 years of running. It would not power on. After reading all of these forums, I concluded that my power supply most be dead. I ordered a new one on Amazon that match the same Voltage, Freq, etc. of the current PS. Install went smooth no issues. I decided to boot it up with no HDDs to verify it worked. It turned on, however, the display screen was lit and display "blocks". The blue glow around the power button did not turn on. I tried turing off the system and it would not. I tried with a quick power button press and also held it for a number of seconds 10+, 20+. No luck. I read that I should be able to see the NAS on the frontpage and I could not. I decided to try it with the HDDs installed. Same issues. The fan is working everything seems to be ok. Thoughts? Thanks!1.5KViews0likes8CommentsReadyNAS Duo failure
I am unable to access my READYNAS. I am guessing it is some sort of internal power failure. The external 12v supply seems to be OK when tested with a meter but the blue power light on the NAS is intermitantly and fairly randomly going on and off. Has anyone else experienced this problem? Thanks for any answers853Views0likes3CommentsReadyNAS Business Pro Power Supply Replacement
Earlier this year my ReadyNAS got double booted in a very short period of time following a power outage that lasted longer than my backup. Afterwards it appeared the PS was dead. I did diligent research here and found a suggestion to buy a Kentec power supply. Although I should have read more, I assumed a PS reccomendation would be plug and play, although I saw some wiring changes would need to be made. I assumed the PS itself would bolt right in. Turns out the sizes are very different. I am writing this to get the word out in case others think they need to buy the Kentec. I hadn't taken my PS out, so I read you could only get them in Europe for a higher price than the Kentec and would still have to get it shipped. Thinking the Kentec would bolt right in and I only needed to solder a couple wires, I ordered one. Unfortunately that was in June and now it is August and I am trying to put it in and finding the two boxes are totally different. Now that I had my PS out, a Seasonic SS-300SFD, I googled it, and sure enough, they are at Newegg and who knows where else... $39 and free shipping and the Kentec was $28. Is it worth dealing with an incompatible box to save $12... Turns out that since I waited two months to install it, I can no longer return the Kentec. At this point I am debating having a new PS that is now a door stop, and spend the additional $39 to get the right PS. I could no longer respond to the topics where this PS was suggested, so I am creating a new topic to raise the question of why someone would suggest a physically incompatible drive to save $12? I guess another option is to have the PS hang out the back somewhere.... As an aside, the Seasonic is 300W and the suggested replacement Kentec is 250W. Please explain what I am not getting here and why this Kentec was suggested, and are people really using these as replacements? Thanks!No detection of "bad" power supply on ReadyNAS 4200V2 with OS6.7.5
Having recently seen a couple of posts from users with 3200's and 4200's with power supply issues, I ran an experiment and unplugged one of the supplies on my 4200V2 running OS6.7.5. While is beeped loudly, there was no message in the log that a power supply had failed. I don't have email alerts turned on, but my suspicion is that it would not have sent one, either. Pulling the supply completely silenced it, but there was still no entry in the log. It made no difference if this was done with power on or it was booted that way. I know OS6 is not officially supported, but it sure would be nice if it did properly detect this, as many with this type of unit administer them remotely. Do the newer rack-mount units with redundant supplies provide proper notification? I only ran this unit briefly with OS 4.2.x, but I am sure that it logged a power supply failure if one was not plugged in to a power source. I don't know if it complained if a supply was pulled completely (I suspect not, as that would be an intentional act).2.4KViews0likes0CommentsPower supply switch set to On when RN526X off for extended period?
Is it safe to leave the power supply switch set to the On position on the ReadyNAS 526X when the system is powered off? After not using my 526X for over a month (it was powered off, but the power supply switch was on), I noticed that the case exterior was warm to the touch. According to the Product Data Sheet, the 200W power supply when the system is powered off consumes only 417mW of power. Should I be concerned about internal heat generated from the power supply possibly shortening the life of the hard drives or other internal components under these circumstances?3.6KViews0likes7CommentsPower supply failure
Hello, I have a RNDP600E and it doesn't start. There seems to be power. No leds on and nothing happens. The power supply is a Seasonic SS-300 sfd. It can be replaced because I cannot buy it anymore. I would like to replace the power supply but I don't know what kind of power supply can be used to replaced it. Maybe before changing it, fuses can be changed ? Does someone know what king of tests I can do to test the power supply ? Does someone know where to buy the same power supply ? Does someone know if I can get my data by using a new NAS and putting the 6 HDD I have in the new NAS ? Thanks for your help. CFOE1.5KViews0likes0CommentsRNDX wont start
Product Model: ReadyNASRNDX4000 Purchase Date: Oct 27, 2011 After a power cutoff my nas wont start. i think psu dead. where can i buy a cheap replacement unit to help me out for a few months,i think iam goin to buy a new nas afterwards. i noticed you can make one yourself but i am not in to this hocus pocus. thx in advance Bert3.2KViews0likes3CommentsInexpensive power supply replacement for legacy 4-bay Readynases
This was posted as a reply to another message, but is reposted here for easier searching. I have now confirmed that a mini-ITX, aka Flex ATX, supply will work as a replcement for the NV, NV+ (v1), NVX, Ultra 4, and Ultra 4 Plus, and I assume Pro 4. Be attentive of the amount of +12V supplied, as it needs to be at least 7A to meet the spec of the original. The 250W supply I got provides 13A, and I wuld expect all 220 or 250W supplies would have enough. One 150W one I saw advertised had only 5A. The connector has to be re-wired per the diagram here: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf. One way to do that is to remove the two pins that are changed to +12V and replace them with the +12V from the 4-pin CPU connector. They are the same type of pin. On mine, the cables are the same length, too. If you have trouble removing them (there is a special tool that makes it easier), you could cut and splice, but that will void the power supply warranty. Either put the removed pins into the 4-pin connector or cover with shrink tubing to prevent them from shorting to the case You will also need to rig up a way to install the air deflector. Some good aluminum tape ought to do it. The vent holes in the one I got are not very large, so I would not recommend removing the fan unless you are willing to take it apart and drill a lot of extra holes in it. Being only a 40mm fan, it has a rather high pitch when fully spun up, but the one I got does have automatic speed control. The orignal Infrant NV I have shipped with a power supply with fan, and it could get a bit annoying. But since many are relegating their older units to backup that only powers up when needed, it would be tolerable unless in a bedroom or something. I have seen these supplies new on eBay for around $30 and elsewhere for a bit more to a lot more.SolvedNV+ RND4000 Power Supply Failure: What are my options?
A few months ago the power supply died on my NV+ v1 (RND4250-100NAS). I tried to contact support as suggested in some other forum posts, but couldn't get anywhere with the online form – it only tells me my product is EOL and provides no options to actually contact anyone or open a case. I've read other forum posts from just a few months ago suggesting it might be possible to get a replacement PSU: https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-NV-Fails-to-Power-Up-after-Power-Failure/m-p/1100816 https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/ReadyNAS-NV-won-t-turn-on-power-supply-issue-27356934/m-p/1124966#U1124966 I've also seen some as far back as a couple years ago saying there are no more PSUs available. It's also not clear whether or not my unit falls under the Service Action, and whether or not that actually matters. So i'm not sure what my options are. I've done all the basic troubleshooting steps like trying different power outlets, and swapping power cords. I remember smelling a burnt electrical smell the time i tried to power it on but it wouldn't. Zero activity since then – no lights, sounds, or anything. It's almost certainly a failed PSU. Serial number: 21T193RE0049
