miahz
Jan 09, 2017Aspirant
NV+ RND4000 Power Supply Failure: What are my options?
A few months ago the power supply died on my NV+ v1 (RND4250-100NAS). I tried to contact support as suggested in some other forum posts, but couldn't get anywhere with the online form – it only tells me my product is EOL and provides no options to actually contact anyone or open a case.
I've read other forum posts from just a few months ago suggesting it might be possible to get a replacement PSU:
I've also seen some as far back as a couple years ago saying there are no more PSUs available. It's also not clear whether or not my unit falls under the Service Action, and whether or not that actually matters. So i'm not sure what my options are.
I've done all the basic troubleshooting steps like trying different power outlets, and swapping power cords. I remember smelling a burnt electrical smell the time i tried to power it on but it wouldn't. Zero activity since then – no lights, sounds, or anything. It's almost certainly a failed PSU.
Serial number: 21T193RE0049
Your system's serial number is outside the range in the service action.
There a couple of third party supplies out there, but they expensive. For instance: http://www.evercase.co.uk/CompatibilityListReadynas.htm
If you have the skills, it is possible to purchase a much less inexpensive supply, and modify the cable pinout.
Netgear support can also help you offload the data using a new X86 OS-6 ReadyNAS. More information is here: http://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6?cid=wmt_netgear_organic
- miahzAspirant
Thanks, StephenB. I'm intertested to hear directly from Netgear, because, as i mentioned, replacement PSUs were recently sent to multiple customers whose units were also not covered by the service action. See the links i originally posted.
