SMART MANAGED SWITCHES
2 TopicsWhich Managed Switch Range?
Hi, Hopefully a very simple question. We are looking for 2 small managed PoE switches (ideally 1x8 port and 1x16 port). However, we're a bit confused by the various models and product ranges. The environment these switches are going into is quite a complicated one with multiple vLans, LAGs between switches and SMNP management/monitoring. We purchased (in error it turns out) GS3108EPP and GS3116EPP. These don't have the necessary depth of configuration to setup the vLANS and LAGs the way they need to be. I'm looking for the next range up in terms of config options. They are replacing a GS716T (going to 8 port one) and a JGS516PE both of which are now discontinued. Can someone please suggest the models we are need to replace them. Many Thanks! Chris.
