SRR60 SRS60 ORBI PRO
6 TopicsI have the Net Gear Orbi SRR660
I have the Net Gear Orbi SRR660. This system has 3 wireless networks. The main network supports both 2.4 and 5Ghz. Wireless network 2 allows me to have a separate SSID for the 2.4 and 5Ghz bands. Wireless network 3 I use for guest devices, like the kids tablets or friends that stop by. I have had this system for a few years. It seems that with the newer versions of devices and updated firmware, Net Gear has taken this functionality out. I assume they did so to make it more common user friendly to setup and use. But, for those folks that are somewhat IT savvy, this is a detriment. The only problem is that the old version won't support Wi-Fi 6 or 7. I do get consistently over 500M throughput both ways on the 5Ghz band, with a 1G fiber connection to the house. I wish Net Gear would spend time and effort to reimplement this capability.SRR60 router red led
From one day to the other my SRR60 router(used as a AP) doesn't work anymore. The led is white pulsing and the power led is green. I tried an factory default but nothing happens when pushing the reset button a while where it should be flashing amber after a couple of seconds. So i tried the 30-30-30 second method. That works but results in only a red led flashing 4 times and becomes green again. Still no results in the browser for 192.168.1.1 and also no ping. Last thing i tried is holding reset button while power on the srr60 until the led flashes red. At that time i have a ping on 192.168.1.1 and i could install the firmware again because i was thinking the FW became corrupt some how . Unfortunately after that no ping and no webpage anymore. The power led is green and the status led is pulsing white. Is there someone with a good idea? Or do i get rid of my srr60 and 3 srs60 Thanks in advance rgds, PaulHelp, I can't enter the system interface after changing the SXS80 model to RBS850
I changed the SXS80 model to RBS850 in Telnet, and wanted to flash the RBS850 firmware, but the firmware failed to pass the verification and could not be flashed. The current problem is that the machine can run normally and can be used normally after connecting to the upper-level router, but the system management interface cannot be displayed, that is, there is no way to turn on the Telnet option and change back to the SXS80 model. Currently, all firmware versions of SXK80 have no restrictions on turning on Telnet. You only need to enter the /debug.html page and check it, but I can't enter it now. I hope everyone can help me and teach me how to force Telnet to open. Thank you.115Views0likes2CommentsSRR60 - random Wi-Fi drops
I have an SRR60 with four active SSID's and about 75 devices connected. (A lot of home automation) A couple times a day, the Wi-Fi seems to shut off. Multiple devices and PC's in the house report no Wi-Fi connection. This occurs on all the SSID's 5 and 2.5 at the same time. About a minute or two later everything restores. I'm on the latest/last firmware. 2.7.3.100. The uptime on the debug page is accurate. The unit is not rebooting. No errors or bad signals on the cable modem. (bridged and no Wi-Fi) Any thoughts or suggestions are appreciated.
