taurus1961
Sep 09, 2025Aspirant
SRR60 router red led
From one day to the other my SRR60 router(used as a AP) doesn't work anymore. The led is white pulsing and the power led is green.
I tried an factory default but nothing happens when pushing the reset button a while where it should be flashing amber after a couple of seconds. So i tried the 30-30-30 second method. That works but results in only a red led flashing 4 times and becomes green again. Still no results in the browser for 192.168.1.1 and also no ping.
Last thing i tried is holding reset button while power on the srr60 until the led flashes red. At that time i have a ping on 192.168.1.1 and i could install the firmware again because i was thinking the FW became corrupt some how . Unfortunately after that no ping and no webpage anymore. The power led is green and the status led is pulsing white.
Is there someone with a good idea? Or do i get rid of my srr60 and 3 srs60
Thanks in advance
rgds, Paul
If the 30-30-30 reset process did bring the SRR back to operation and getting access to the setup web page, unit is probably gone bad and needs to be replaced.
- taurus1961Aspirant
The 30-30-30 process unfortunately did not bring back the SRR. Only thing was that the unit was pingable on 192.168.1.1 and i could update the (maybe)broken Firmware with success so that was a hopefull. Web page wasn't reachable.
It looks that all the 3 satellites (SRS) works okay without the SRR. Look to me that this is not normal.
