taurus1961
Sep 09, 2025Aspirant
SRR60 router red led
From one day to the other my SRR60 router(used as a AP) doesn't work anymore. The led is white pulsing and the power led is green. I tried an factory default but nothing happens when pushing the re...
Sep 09, 2025Guru - Experienced User
If the 30-30-30 reset process did bring the SRR back to operation and getting access to the setup web page, unit is probably gone bad and needs to be replaced.
taurus1961
The 30-30-30 process unfortunately did not bring back the SRR. Only thing was that the unit was pingable on 192.168.1.1 and i could update the (maybe)broken Firmware with success so that was a hopefull. Web page wasn't reachable.
It looks that all the 3 satellites (SRS) works okay without the SRR. Look to me that this is not normal.
- FURRYe38Sep 09, 2025Guru - Experienced User
