Smart Cradle
2 TopicsDC112A Smart Cradle Solid Amber Light Internet Connection
I have a DC112A Smart Cradle on firmware 1.0.0.30 with a 781S AirCard connected to it. When it is first turned on everything works fine. After a few hours a solid amber light turns on under the Internet Connection symbol. When this happens I lose all internet connection. The AirCard never looses connection to the AT&T network. It always shows a full signal. If I unplug the AirCard from the Smart Cradle and restart it then plug it back in the internet connection lights up green and starts working again. This is really becoming a problem because I can't access my Smart Door Lock and Video Doorbell when I am not at home because the network connection goes offline. If anyone has any suggestions please let me know. Thanks!Traffic Meter Cannot Activate on Aircard Smart Cradle DC112A
Hi folks Using DC112A with unlocked Telstra AdvanceIII WiFi hotspot in the cradle. I am on Win10 64bit. Internet Provider = Vodafone and the internet is via 3G Mobile Broadband only (hence my desire to have a functional Traffic Meter) :smileyfrustrated: Traffic meter activation fails when using Geneie web interface (when you try to click 'Apply') with these messages given on web interface: "Only use mobile broadband (wireless network provider) not support traffic meter, please uncheck to disable it." If you un-check this option and choose any other option, it will give the same warning message (but with the different option wording put in) and saying that you need to deselect that as well. In other words, it doesn't matter what option you select, it fails to activate the traffic meter (whether or not you put values into the various boxes). Can anyone please help on this matter? With Thanks Jag.
