Smart Switch
73 TopicsSelf-Signed Certificate option for 8-Port Gigabit Ethernet PoE+ Plus Switch (GS308EP)
Hello, The following product does not have ability to add a self-signed certificate. Therefore, credentials are entered in plain text which is insecure. All switches should have this basic but fundamental feature as a bare minimum for security. I have contacted support already and they said to make a feature request here. 8-Port Gigabit Ethernet PoE+ Plus Switch(GS308EP) Thank you for considering.70Views0likes1CommentSwitch GS105Ev2 foutmelding kabeltester
Ik heb de switch op poort 1 rechtreeks aangesloten op mij Ziggo Sagemcom modem en uit de kabeltest blijkt op poort 1 een mismatch Cable default 6 meters Het vervangen van de netwerkkabel tussen modem en switch geeft hetzelfde resultaat. Hoe kan ik deze melding oplossen?Trunk Port for 802.1X
We have about 120 Netgear GS110TPv3 switches in use for connecting end user equipment. The switches are great because they support 802.1X, allowing us to dynamically assign VLANs to ports. The Disadvantage is that we also need GVRP because there is no way to set the uplink port as "General trunk port" or "Uplink port" (or is there a way I do not know?). It would be great if I can set a port to "Uplink" or "Trunk Port" and the switch is adding this port tagged to all known and learned VLANs (like VLANs learned via 802.1X) automatically.869Views0likes1CommentTemperature monitoring and control on Smart/Plus switches
I own an XS724EM 24-port 10G switch. It runs warm to the touch, and the default fan profile seems to err on the side of low noise rather than cooling. Tech support says that the switch is designed to spin down fans entirely unless a certain temperature threshold is reached. Personally, I would prefer to see more aggressive cooling, even if meant slightly more fan noise. So my feature request is twofold: Basic temperature monitoring (ambient, internal) in the admin GUI. All I want is a simple readout of how warm the switch currently thinks it is. Basic manual fan control in the admin GUI. I'm envisioning something like the "Cool/Balanced/Quiet" drop-down menu (see image) found on ReadyNAS units. I know the managed switches have functionality along these lines. To me, this basic temperature monitoring and control seems like it should definitely be included on Smart/Plus switches too.2.6KViews5likes2Commentsimprove WebUI GS724Tv4: Time Configuration (SNTP)
Summer Time Configuration improve the description of the fields to be "Offset Minutes" instead of just "Offset" because this is misleading as one assumes "Hours" (as it is in "Time Configuration") also slightly better "Time Zone Name" instead of just "Zone" (as it is in "Time Configuration")1.6KViews1like1CommentTrunk poorten in samenwerking met KPn v12 box.
Dag, Netgear switch GS716TP met daarop AP WAX625. Op deze AP een VLAN (8) aangemaakt t.b.v. een gastennetwerk. Gastennetwerk mag alle beschikbare banden gebruiken. De switch zit op poort 1 verbonden met de KPN v12 op poort 4 De AP zit op poort 11 van de switch en is getrunked met poort 1 op de switch. Client isolation ingeschakeld zodat eventuele gasten altijd gescheiden blijven van het zakelijke netwerk. Op poort 1 zit dus nu zowel VLAN 1 (office = vaste gebruikers) en VLAN 8 het gastennetwerk. Er is een captive portal aangemaakt Echter…verkrijg ik geen ip adres vanuit de router op deze trunk. Welke poort(en) moet ik via Access Control op de v12 box openzetten zodat ik een ip adres verkrijg? De ‘normale’ VLANS’ (Office & Groundfloor) werken naar behoren. Kan dit überhaupt op een KPN box v12? Welke External en Internal poorten kan ik ingeven bij Access controle in de KPN box zodat ik eventueel eens kan experimenteren? Grt, Vicount.mail-server without username+password
acutally i cant send logging over email using a mail-server without username and password. in many environments there is an smtp in management lan without authentification. this should be enabled as its an easy change for devs. also i dont get an useful error message after loggin email test fails. thats very bad. also all logging is very rare and bad1.1KViews0likes2Commentsnetgear community bugs
for about a year netgear did not fix community bugs: a) i cant select label Managed Switch so i always have to select Smart Switch. b) i dont want to enter product name everytime as i always suggest for one product only most times. so i prefer a default or dropdown list of reg. products or main lines. c) if i get an error from invalid label i get a flood protection warning if i retry. this is too strict and should not apply on errors which are no flood.841Views0likes1Comment
