Tips from other users
3 TopicsCan no longer use nighthawk app or routerlogin.net, they just do not load.
I have made a mistake somewhere and now when I try to log into the ip address or routerlogin.net, it tries to load, but to no avail. I am also unable to use the Netgear Nighthawk app, strangely I am still able to connect to the internet, all be it slower speeds, much slower. This all started because I plugged a removable usb drive into the back of the router and set up Ready Cloud, after doing so, I was still unable to access the usb drive and the above problem happened with me not being able to connect to the router settings. Since I cannot connect to the router settings, I cannot reverse or unregister from Ready Cloud in hopes that will fix my problem. The windows error message I get when I run a network diagnostic test is this; The remote device or resource won’t accept the connection. If it helps, I am running Windows 11. Please help, I have a house full of smart home devices and cameras and really do hope that I don't have to reset the router but can find a fix. Thank you, Caleb White743Views0likes1CommentQuestion re: USB wifi
I have a Nighthawk AC1900 Smart WiFi Router (Model R7000), and it's excellent. I've got it connected to my sister's desktop computer (Dell Optiplex) via an ethernet connection, and we both use our laptops to connect via WiFi whenever we need to. I also have a Dell XPS Studio 9100 desktop that I want to get a USB WiFi adapter for, and wondered if anyone could recommend a good one? I want to use the 5GHz band to connect, and I understand some WiFi adapters don't support that.Solved3.9KViews0likes5CommentsPlease teach an idiot Link Aggregation
Hi, I need some help. I have a nighthawk R8500 and a ReadyNAS 214 which I would like to use link aggegation on. All my attempts thus far have failed. Please explain to me what exactly I have to do and what settings I should use as far as hashes etc are concerned. i am operating a totally MAC system and my R8500 is connected to the cable modem forum my Internet provider which is JCOM here in Tokyo. My primary use will be to stream iTunes and contain personal data. thank you HerbertSolved4KViews0likes2Comments
