advanced features
2 TopicsReadyOS 6 and AFP over IPv6
I filed a case with Netgear technical support back in July of 2013 (case #21585012) about AFP how AFP wasn't working over IPv6 on my new ReadyNAS RN316 (ReadyOS 6.0.8 at the time). That case was closed on 8/20/2013 with the following response: I apologize for the long delay in getting back to you as I was awaiting words back from engineering. I was able to confirm that this fix should be addressed in the 6.1 firmware release due to be out in a month or so. Let me know if there is anything else I might be able to help answer for you, thanks. In October of 2013, I filed a new case (case #22043449) about the same issue in 6.1.3. This was 'escalated' to L3 support (which did nothing). Here we are in 2015 and ReadyOS 6.4.0 and to my (lack of) surprise, AFP over IPv6 still doesn't work. This works flawlessly on my Ultra 4 Pro with the old OS (4.x). Has anyone ever tried AFP over IPv6 ? Any pointers how to make ReadyNAS care about this issue?Solved3.6KViews0likes4CommentsReadyNAS storage over Internet access
I can't do anything with my files over the internet on the USB storage I have attached to my router. I can connect to the USB drive via Ftp and I can see the files and so on but I can't copy/delete/view/rename/or transfer anything to or from the storage. Why? I would appreciate help greatly. Remote Management: On FTP (via Internet): Enabled (In the USB Storage advanced settings) HTTPs (via Internet): Enabled (In the USB Storage advanced settings) Read/Write rights: "All (No password)" (In the USB Storage advanced settings) Admin on router-login OS X Yosemite4.6KViews0likes9Comments
