advanced features
9 TopicsUsing wifi router as an access point
OK, this is an oldie but a goldie! I have an old Netgear FWAG114 a/b/g wireless router that I'm using as an access point. I've disabled DHCP (my Netgear WNR2000 is assigning IP addreses) and connected it to the WNR2000 - port 1 on the 2000, WAN port on the FWAG114. NADA!!! If I connect it to one of the LAN ports on the FWAG114 it works fine. The kicker is, I used a setup similar to this with my Netgear FVS338/WAG304 and the FWAG114 for about 5 years and it worked perfectly connected via the WAN port. Any ideas???Solved15KViews0likes13CommentsBT OpenReach FVS336Gv2
When I conect my Netgear ProSafe FVS336Gv2 ro my BT openreach Modem it nworks fine. Soon as I switch it to Classic Routing to prepare setup my computers iusing the 5 fixed IP numbers I have pruchased with BT I get no DNS. It' os working fine on NAT, not on Classic, with or without DHCP. It say's I am connected in the WAN Status and PPPOE is connected. I just get no web browsing at all :-( DNS appears to be not working. Is Classic really not doing any routing at all it seems ?!3.5KViews0likes2CommentsProduct replacement for FVS336GV2
Hello the community, I'm searching an actual product able to replace the FVS336GV2, I don't need WIFI, just 2 LAN connection and the most important is the VPN possibility with the old NETGEAR ProSafe VPN client. Thanks for answer me. Regards Damien4KViews0likes2CommentsWhich routers are VPN servers?
Is there a simple way to find out which Netgear routers can be configured to be VPN servers? This is not one of the search criteria options and even when looking at the individual specifications, it's hard to tell if a model supports this feature or not.2.8KViews0likes3CommentsPort forwarding and blocking
I got a UTM5 and for some unknown reason ports such as 445 are not even hitting the firewall. No packets are even touching this thing which leads me to belive my isp (Time Warner) is blocking. I spoke to three level 3 techs who all confirm Time Warner does NOT block and ports. I have other ports open and working fine such as 3389. My modem is Netgear CM600. Netgear Level 2 support is clueless to what is happening since the utm5 is configured properly. Does anyone have any idea what the problem is?2.2KViews0likes0CommentsFVS336G How enable for Spanning Tree Protocol?
Hello, I am using the product FVS336G as my router & firewall. I have noticed that it does not work with my 4 Sonos music players if they are connected to different ports of FVS336G. I researched this issue. This effect is apparently due to the fact that FVS336G does not support STP, "Spanning Tree Protocol". My question: Is there a way to enable Spanning Tree Protocol ability in FVS336G? Thanks mdl91072.9KViews0likes1CommentFVS318G VPN failure
I have a FSV318G for years. I'm using shrewsoft VPN client to to connect to it from multiple locations and its worked for months and months with no problems until last thursday... Now I can't connect to the VPN router from any client. Shrewsoft client output: config loaded for site 'office.vpn' attached to key daemon ... peer configured iskamp proposal configured esp proposal configured client configured local id configured remote id configured pre-shared key configured bringing up tunnel ... network device configured tunnel enabled negotiation timout occurred tunnel disabled detached from key daemon Which usually indicates that phase one completes. But the router VPN logs: 2015 Oct 28 12:24:41 [FVS318g] [IKE] Phase 1 negotiation failed due to time up for 17.58.98.236[500]. 7dbe94b6e00a6439:1152eb82ad35cc99_ 2015 Oct 28 12:23:41 [FVS318g] [IKE] Setting DPD Vendor ID_ 2015 Oct 28 12:23:40 [FVS318g] [IKE] For 17.58.98.236[500], Selected NAT-T version: draft-ietf-ipsec-nat-t-ike-02_ 2015 Oct 28 12:23:40 [FVS318g] [IKE] Received Vendor ID: CISCO-UNITY_ - Last output repeated 5 times - 2015 Oct 28 12:23:40 [FVS318g] [IKE] Received unknown Vendor ID_ 2015 Oct 28 12:23:40 [FVS318g] [IKE] Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02__ - Last output repeated twice - 2015 Oct 28 12:23:40 [FVS318g] [IKE] Received unknown Vendor ID_ 2015 Oct 28 12:23:40 [FVS318g] [IKE] Beginning Aggressive mode._ 2015 Oct 28 12:23:40 [FVS318g] [IKE] Received request for new phase 1 negotiation: 10.1.10.191[500]<=>17.58.98.236[500]_ 2015 Oct 28 12:23:40 [FVS318g] [IKE] Remote configuration for identifier "pb.local" found_ There is a cable modem router in front of the FVS318G buts its been there all along. HelpSolved8.5KViews0likes8CommentsReadyOS 6 and AFP over IPv6
I filed a case with Netgear technical support back in July of 2013 (case #21585012) about AFP how AFP wasn't working over IPv6 on my new ReadyNAS RN316 (ReadyOS 6.0.8 at the time). That case was closed on 8/20/2013 with the following response: I apologize for the long delay in getting back to you as I was awaiting words back from engineering. I was able to confirm that this fix should be addressed in the 6.1 firmware release due to be out in a month or so. Let me know if there is anything else I might be able to help answer for you, thanks. In October of 2013, I filed a new case (case #22043449) about the same issue in 6.1.3. This was 'escalated' to L3 support (which did nothing). Here we are in 2015 and ReadyOS 6.4.0 and to my (lack of) surprise, AFP over IPv6 still doesn't work. This works flawlessly on my Ultra 4 Pro with the old OS (4.x). Has anyone ever tried AFP over IPv6 ? Any pointers how to make ReadyNAS care about this issue?Solved3.6KViews0likes4CommentsReadyNAS storage over Internet access
I can't do anything with my files over the internet on the USB storage I have attached to my router. I can connect to the USB drive via Ftp and I can see the files and so on but I can't copy/delete/view/rename/or transfer anything to or from the storage. Why? I would appreciate help greatly. Remote Management: On FTP (via Internet): Enabled (In the USB Storage advanced settings) HTTPs (via Internet): Enabled (In the USB Storage advanced settings) Read/Write rights: "All (No password)" (In the USB Storage advanced settings) Admin on router-login OS X Yosemite4.7KViews0likes9Comments
