advanced features
682 TopicsAircard 763S MEP Unlock tool for Windows 10
I want to unlock my Aircard 763S but I am having issues downloading and running Aircard Watcher. I have downloaded and started the exe file from http://downloadcenter.netgear.com/en/#searchResults but it will not run on my Windows 10 OS. I can not find that the program has been loaded and installed either. Is there a more up-to-date download file that I should use? Need some help on this as I am stuck. Also, does anyone have the unlock MEP code for the Roger's version of this? Thanks a lot. ErikNetgear A6210 not showing 5ghz band
Hello, I've purchased this A6210 dongle around 3 months ago, the 5GHz was working fine around 2 month and just one day stopped working. I didn't have the time to try and solve it, so I've just used the 2.4GHz, now I'm trying to solve it and nothing is working. I tried to: 1. Uninstall-install (driver alone, and software and driver - version 1.0.0.34) 2. Change USB connector position 3. Configure "Only 5GHz" - not showing my network etc. This is really annoying that I can't use the 5GHz - do you have any suggestions?Solved9.2KViews0likes7CommentsAircard 763S MEP Unlock tool
Help! Trying to unlock the aircard (763S) but the link provided by Fido (service provider) is to a Sierra wireless website and does not work. I have installed the drivers, have an unlock code, but I haven't been prompted to enter it. Using a Mac - OS X El Capitan 10.11.13. HELP ME! Thanks.Solvednew idea for security for all modem and raouters
update your security new inteligent firewall and monitor so you can see what is passing over the firewall and what is bloking in real time like attack ,junk,virus,scrips attack,dos,ddos,bots,malware,exploit bloking,portscan,domain infected,dns,ip ,devices ect IP spoofing attack dns poisoning attack arp poisoning attack tcp and upd port scaning attack protocol SMB attack protocol RPC attack protocol RDP attack Man in the middle attack Session hijacking Server spoofing Ping broadcast Ping of death Smurf Teardrop syn flood brute force ect so you can you can block any coonection with servers ,dns,ips,uknow device conected to the firewall,like hakers ,ect make allow rule or deny so you can deside what block or not or the same firewall tell you that is safe or not makenew ids protection and new gen intrution prevention ( fix all false and positive attack ) network monitor so you can block or deny network too of devices see all conection conected and full speed running so you can see what speed is running like 50mbs or more ect see ping and pakage lost and signal stable and see lag spike ect like for example xboxone or ps4 make new inteligent anti exploit protection protect from any exploit and zero exploit over the network or any new atack tech make memory protection ,protect from any attaack from memory modem or raouter make ready nas and share protection make usb protection make new anti dos or any attack wirless make anti jamming wirless for 2.4ghz and 5ghz prevent wirless drops and secure voice ect make a new turbo nat for gaming make new turbo firewall fix the dos and portscan and security make modem slow playing online games speed up the setting that dont affect gaming on any security setting scrip protection make anti bypass firewall make new unpnp protection make hhtps login and secure make dns protection make new gen turbo qos gaming set upload and download speed make a new modem or router speed test fix put the same ip on portward dont work fix that like example fist ip 192.168.10 for xbox second ip 192.168.9 for xbox in case the ip change dont let you fix that dont support mutiple ip make a new disnotic mode test security or vulneravility settings you have make new smart ip conflic fix make new uknow change have been made incase of hakers and what setting was change make turbo chanels for download and upload make to change upload and download frecuency make a new gen modem software for all make super fast software fix always disconection on modems for gaming make super fast cpu 4 core 2.20ghz or higth turbo for modem ect make gaming modem make smart porforward ports nope error and security make support ipv6 for portfoward and all settings like dns ip ect make to disable ready share for the modem add protection for printer security cold be vulnerable and easy for hakers make anti remote bypass and security wps security ect just helping30KViews7likes2CommentsA6210 cannot create wireless hotspot!!!
I have created numerous hotspots with other usb adapters. Windows 7 has a built in functionality of allowing wireless network adapters to create hotspots to share internet. This can be done directly through the windows elevated command prompt, or using a 3rd party software that has a nicer UI such as Connectify. Here is a basic tutorial about creating a hotspot: http://www.wikihow.com/Create-a-WiFi-Hotspot-Using-the-Command-Prompt However, with the A6210, hotspots cannot be created at all. Only an error message is shown about "microsoft hosted network could not be started". I have tried every driver on the netgear website, but none work. Please investigate this issue as it is a very very basic function of a usb adapter.17KViews1like9CommentsR8000/R7900: No Wireless Bridge Mode?
Surprised to see that there is no bridge mode option in R7900/R8000 admin settings. The only feature that's available is the Wireless AP mode. Is this correct? Am I missing something? Even on the R7000, there is an option under Advanced Setup > Wireless Settings to convert one of the radios to connect to another router (Use other operation mode > Setup Bridge Mode Wireless Settings). Is there any reason why this would be disabled on the R8000/R7900? Is there a firmware version that still has this feature enabled that I can revert to? I have the R7900 variant, and my current firmware is 1.0.1.4. To clarify, I'm not talking about bridging an IPTV to the Internet or using the R8000/R7900 as an AP. I'm talking about getting the R8000/R7900 to wirelessly bridge with another wifi router.Solved65KViews0likes22Comments
