ax8
47 TopicsEAX80 Nighthawk AX8 Reset and Cannot Connect
I needed to reset my EAX80 Nighthawk AX8. I pressed the reset button for 7 seconds and after I let go, the router rebooted. By the fact that my SSIDs were no longer transmitting and a new SSID NETGEAR appeared, I believe it reset fine. Problem is that I cannot connect to it to reconfigure it. I have attempted to connect to it with my cell phone after disconnecting from my normal WiFi and turning off mobile data. Most of the time the cell phone says Connecting, No Internet, Saved. Once in a while it will remain connected, but my Nighthawk app will not find the router. Most times, the cell phone has disconnected. I have plugged the the Ethernet cable directly into my PC (Windows 11) and attempted to open the IP of my default gateway 192.168.1.230 but the web browser says no page found. I have used the AX8 as a hub and attempted to open the web page. No page found. I have also attempted to use my laptop (Windows 11) and attach to the NETGEAR SSID but still cannot keep a connection and cannot open the IP when it does stay connected. Any other ideas?4.2KViews0likes8Commentsnighthawk app can't modify settings when nighthawk cax80 modem is offline
My cable modem (with wifi router) CAX80 can connect to the internet over the coaxial cable. The Xfinity tech came over and set up the connection. I decided to take the modem offline in order to change the settings on the WiFi router. I prefer changing the WiFi settings before turning the WiFi on. I have the nighthawk app installed on my Pixel 6 - I was able to log on to the router using an ethernet cable - however, when i start changing the password and security questions, it will not save the new data. The error message says that the routerlogin.net/..... site is unreachable. I also tried logging into the router using my PC, with the same results. I can get to the page for changing the password. Saving the information does not work. As a last resort, I logged onto the router using WiFi. It asked for the serial number, but on the next page, I got an error: http://192.168.1.1/goform/PwdRecCheckserial?id=.... is unreachable. Do I really need the connection to the internet in order to access/modify the router settings ? Thanks.Solved1.8KViews0likes1CommentNighthawk CAX80 modem/router drops connection daily, including LAN
I've been having issues for a little over a week now with a 9 month old CAX80, my internet went down for scheduled work by Xfinity and since it's come back, I've been having security certificate issues in chrome on all my devices and my network goes down multiple times a day for maybe 10 or 20 minutes at a time or until restart the router. When it happens, my local wired connections go down (which makes me think router problem,) but wifi stays up without connecting to the internet. Has anyone had any experience with this sort of thing? I've asked neighbors and xfinity, it doesn't seem to be happening to anyone else here. Also, did a new firmware come out recently? I'm thinking of downgrading and seeing if that changes anything.830Views0likes1CommentAX8 Nighthawk drops signal strength for no reason
So my AX8 will just drop the strength to all of my devices for no reason. I noticed it more since i began streaming games from my PC to my iPad. I checked the the signal strength in the app to my devices and it was one bar on everything (all wifi devices though show strong connection on the devices themselves). I found that doing a speedtest kicks the router in the butt and seems to get things back to a tolerable level for a little bit. See the screenshot to see the before, and then immediately after running a speedtest. Any ideas?1.4KViews0likes5CommentsCAX80 test speeds
hello everyone i'm still waiting on netgear to get back to on support i emailed them because the phone support tells me don't worry anything else your online. i get different issues all the time I've done 4 factory resets ,one time it kept telling me i was connected remotely and all my info was the same but no Internet. right now i can only connect to my modem thru my computer, nighthawk app quit and put me in remote access again all my devices are gone again. testing speed im wireless right now becuase my wife is sleeping on the couch on my 5g xfinity speed 561.0 speedtest 762.66 my 5g guest network is xfinity 236 speedtest 292 there is nothing on my guest networks but me testing 2.4 xfinity 82.5 speedtest 59.79 average over multible tests 2.4 guest xfi 65.8 speedtest 59.7 i know 2.4 is slower but this much difference when the app did work 2.4 was 431. on speedtest the other thing is streaming amazon i get a german message first then japanese then UK and finnally english saying it timed out. didnt happen with xfinity modem/routerNighthawk AX8 firmware update wifi issues
So I complete a firmware update yesterday and now the system can't recognise the 2.4 and 5 G wifi. I also have many smart devices connected and now they don't connect properly. I see a new smart setting which will allocate devices to which wifi they will connect to but this does not work either. firmware version V1.0.5.126 APP version2.10.5.17 Any ideas as I can't get support from Netgear.1.9KViews0likes5CommentsImages slow to load early morning
Images on my Facebook newsfeed slow to load early in the morning. Typically 5am - 8am. It happens sometimes during the day, but only for a few minutes. Is it most likely Fios, or Nighthawk? When I do a speed test on my iPhone while it’s happening, internet download speed is about 60-80 mbps. Should be at least 200mbps508Views0likes0CommentsX8 R8500 + EX8000 or Orbi AX6000? Which is best?
I currently have an X8 R8500 but we still have some dead/weak spots in the house so I have a few questions for those more familiar with Netgear. Will the EX8000 work with my X8 R8500 to extend? How about the EAX80? Would it be better to get the Orbi AX6000? What would I gain or lose between the Orbi AX6000 vs the X8 + EX8000? How about the EAX80 instead of the EX8000? I am always up for upgrading but the Orbi price tag is a bit steep. At the same time, I'm concerned about losing some usability with the consequences of the backhaul using the R8500 + EX8000 set up. I'm guessing that one of the 3 bands gets taken up for backhaul tasks. The EAX80 is listed as dual band so it seems it would be even more impacted. I know I could run CAT 6 for the backhaul but that wont be an option for a while and may not be an option for some areas. I have read up on these mesh systems and extenders a bit but I'm just not sure how these in particular would work together and how it would compare to the Orbi AX6000. If keeping the R8500 and extending off of it with one of those extenders didn't cause a reduction in services and I'm not missing much by not taking the opportunity to upgrade to the AX6000 I would consider keeping it. If the AX6000 was enough pure improvement, I would consider it. Your thoughts, opinions, and education are greatly appreciated.2KViews0likes4CommentsNighthawk RAX80 very unstable - losing connections
Hi all, I've bought the RAX80 six weeks ago and it's been very unstable since then: - devices losing wifi connections - devices not seeing the wifi network - RAX80 losing internet connection (orange led) I did resets to factory settings several times (with rebooting modem, RAX80 and all the connected devices). I only use default settings now - with Smart Connect enabled. No extra wifi6 settings like MU-MIMO. But nothing works. After a few days all the problems above come back again. I'm very disappointed in this 300 euro router. In times like this with working at home en schools closed losing wifi and internet connections is very frustrating. Is there something I can do about this problem - except for returning the RAX80? Thanks
