connection error
3 TopicsWindows 10 Install: no longer able to access NAS shares
Hi, I upgraded 3 days a go to Windows 10 Enterprise build 16299. It was an installation from scratch I sadly have no longer access to any of my SMB shares. Access was working on Windows 7: see image below - I tried dropping to SMB1 in SMB Application + reboot both PC and NAS: no success - I disabled IPV6 under LAN adapter in Windows 10: no success - I enabled every sharing option under Windows 10 for both Private and Public networks: no success Using cmd in admin console to map the network share: net use * /delete net use t: \\nas-ip-address\data /user:admin nas-admin-password Under the shell cmd, I have access to the shares and their listing through drive T: However, it is wired that Explorer GUI cannot access to the T: drive. So I still cannot see my shares in GUI Under Explorer, I can see the NAS: - under "Media Devices", and brows the DLNA folders - under "Storage", double clicking brings the NAS web admin GUI - under "Computer", named correctly "NAS-01": but if I try to access the shares it gives me a "Network access error" I attach above the image with my error Please help me fix this asap, I am lost and really need the SMB access to manage my backupsSolved44KViews0likes5Commentsreadycloud uploading failures
I started uploading files on readycloud early this morning and was sucessful. about 2 hours later I tried again and got failures It is stating in the failure that their was a connection error. Is the system down? Are their problems on the netgear cloud? I have tried different browsers Silverlight and reloaded Chrome with no success. This seemed to have started around 9:30am EST and am still not able to upload at 1:00pm EST Today is 11/12/17Solved3KViews0likes2CommentsLogin Page Dead with Chrome - Edge works
If I try to log in to 192.168.1.1 with Chrome, I get 192.168.1.1 refused to connect. However, if I reboot the router and use Edge, I'm able to log in. If I try Chrome again, I get the above error and Edge can't connect any more. I have to reboot the router to regain access to the login page. Once it's rebooted, I can only use Edge to access it. Once I use Chrome, it kills access. Anyone know how to fix this? Seems Chrome is causing an issue.Solved7.8KViews0likes8Comments
