connection error
1 TopicLogin Page Dead with Chrome - Edge works
If I try to log in to 192.168.1.1 with Chrome, I get 192.168.1.1 refused to connect. However, if I reboot the router and use Edge, I'm able to log in. If I try Chrome again, I get the above error and Edge can't connect any more. I have to reboot the router to regain access to the login page. Once it's rebooted, I can only use Edge to access it. Once I use Chrome, it kills access. Anyone know how to fix this? Seems Chrome is causing an issue.Solved8KViews0likes8Comments
