dépannage
3 TopicsNETGEAR Orbi RBK12 /NordVPN and Chromecast
Orbi RBK12 and a VPN and Chromecast (Google) To cast from an Android phone to TV with Chromecast the phone and the TV shoud be on the same wifi. I use on my phone a VPN (NordVPN) and my Wifi but Chromecast considers that is no more the same Wifi. I should parameter my Orbi that it uses this VPN? But is possible? and How? Thank you for your adviceMy phone (android) just can't connect to router N300 Trek PR2000
Hello, I'm having troubles with connecting my phone to my router (N300 Trek PR2000). I bought this router 3 years ago and it always worked fine until recently, now I'm unable to connect my phone (Huawei P10 lite, under Android). After I enter my NETGEAR password, it leads me to the Genie interface tab where it can't find my router on the list. When I try to connect to the router manually, it cannot connect either. I tried many times restarting the router and my phone, resetting the router and nothing works, Genie cannot find my router on the WAN list of network. I tried to "configure the internet connection myself", but it didn't change anything. I didn't have any problem to connect my computer though, it's only with the phone. Some information about the config: Router information: Router Firmware Version: V1.0.0.09_1.0.1 DHCP Server: On Mode: Wireless Hotspot Internet port MAC Address: C4:04:15:78:B4:51 IP Address: 0.0.0.0 Connection: DHCPClient IP Subnet Mask: 0.0.0.0 Domain Name Server: 0.0.0.0 Hope you can help! Thank you in advance. p582Solved3.8KViews0likes2Comments
