factory reset
1 TopicCannot connect to WAC730 after factory reset
Please help. I am unable to access the AP after a factory reset. All the lights are coming on as normal. The router sees it and assigns it an IP. However, when I try to access the management page on that IP I get no response. I tried on 2 different routers. I know the reset occurred because the broadcast SSID reverted to the default. When I try to connect to the default SSID i dont even get an IP address assigned. The reason I had to factory reset is I incorrectly setup a vlan and the AP got isolated from the network and became inaccessible.Solved11KViews0likes12Comments
