installation & upgrade
5095 TopicsSwitch GS108E v3 language problem
Good afternoon Switch GS108E v3 I am in the UK. I have just purchased (from the Netgear site on Amazon) a managed switch GS108E v3. I mostly use Linux. When accessing the switch user interface from a browser it appears to be in the Chinese language. Because of this I cannot read any of the heading to change it to English. With a google I'm advised to download the Netgear ProSAFE program on a Windows computer from which I will be able to download the English firmware. When attempting this the ProSAFE program (although seeing the switch) will not allow me to login to the switch giving me the message... "The Plus Utility management is currently disabled on this switch" Any suggestions? Regards to all readers. AndySolvedRN104: ghost “NG-8TB-Seagate” volume (RAID unknown) Inactive/Unprotected
I have a ReadyNAS RN104 that’s working fine from the data point of view, but the volume configuration seems corrupted and is generating constant volume health alerts that I cannot clear. I’m hoping someone familiar with the ReadyNAS OS 6 config DB can advise on a safe way to remove the ghost volume entries without wiping any data. Hardware / firmware: • Model: RN104 • OS version: 6.10.10 • Disks: • sda: 2 TB (NG-WDRED-2TB-1) • sdb: 6 TB (NG-WDRP-6TB-1) • sdc: 3 TB (NG-WDRED-3TB-2) • sdd: 8 TB (NG-8TB-Seagate) – recently replaced a failed 3 TB Symptom: In the web UI → System → Volumes I see 6 volumes even though I only have 4 disks. The top four are green JBOD volumes with data and look healthy: • NG-8TB-Seagate (JBOD, ~7.27 TB, ~2.64 TB used) • NG-WDRED-3TB-2 (JBOD, ~2.72 TB, ~1.17 TB used) • NG-WDRP-6TB-1 (JBOD, ~5.45 TB, ~4.28 TB used) • NG-WDRED-2TB-1 (JBOD, ~1.81 TB, ~0.2 TB used) Below those, there are two blue entries with 0 data and “RAID unknown”: • NG-WDRED-3TB-1 (0 data, 0 free, RAID unknown) • NG-8TB-Seagate (0 data, 0 free, RAID unknown)RN104: ghost “NG-8TB-Seagate” volume (RAID unknown) flapping Inactive/Unprotected
Hi all, I have a ReadyNAS RN104 that’s working fine from the data point of view, but the volume configuration seems corrupted and is generating constant volume health alerts that I cannot clear. I’m hoping someone familiar with the ReadyNAS OS 6 config DB can advise on a safe way to remove the ghost volume entries without wiping any data. Hardware / firmware: - Model: RN104 - OS version: 6.10.10 - Disks: - sda: 2 TB (NG-WDRED-2TB-1) - sdb: 6 TB (NG-WDRP-6TB-1) - sdc: 3 TB (NG-WDRED-3TB-2) - sdd: 8 TB (NG-8TB-Seagate) – recently replaced a failed 3 TB Symptom: In the web UI → System → Volumes I see 6 volumes even though I only have 4 disks. The top four are green JBOD volumes with data and look healthy: - NG-8TB-Seagate (JBOD, ~7.27 TB, ~2.64 TB used) - NG-WDRED-3TB-2 (JBOD, ~2.72 TB, ~1.17 TB used) - NG-WDRP-6TB-1 (JBOD, ~5.45 TB, ~4.28 TB used) - NG-WDRED-2TB-1 (JBOD, ~1.81 TB, ~0.2 TB used) Below those, there are two blue entries with 0 data and “RAID unknown”: - NG-WDRED-3TB-1 (0 data, 0 free, RAID unknown) - NG-8TB-Seagate (0 data, 0 free, RAID unknown) I believe these are stale/ghost volumes from the old failed 3 TB drive and some mis-step when I first added the 8 TB. They show only “Disk test” and “Destroy” as options. When I try “Destroy” on the old 3 TB entry, it appears to succeed but the entry comes straight back. In the logs I constantly get messages like: - “Volume: Volume NG-8TB-Seagate health changed from Inactive to Unprotected.” - “Volume: Volume NG-8TB-Seagate health changed from Unprotected to Inactive.” These repeat every few seconds/minutes and are clearly coming from the ghost NG-8TB-Seagate entry (the 0-data, RAID-unknown one), not the real 8 TB JBOD volume which is mounted and in use. SSH diagnostics (all arrays look clean): lsblk sda 1.8T ├─sda1 -> md0 (/) ├─sda2 -> md1 (swap) └─sda3 -> md126 /NG-WDRED-2TB-1 sdb 5.5T ├─sdb1 -> md0 (/) ├─sdb2 -> md1 (swap) └─sdb3 -> md127 /NG-WDRP-6TB-1 sdc 2.7T ├─sdc1 -> md0 ├─sdc2 -> md1 └─sdc3 -> md125 /NG-WDRED-3TB-2 sdd 7.3T ├─sdd1 -> md0 ├─sdd2 -> md1 └─sdd3 -> md124 /NG-8TB-Seagate /proc/mdstat md124 : active raid1 sdd3 7809175808 blocks super 1.2 [1/1] [U] md125 : active raid1 sdc3 2925415808 blocks super 1.2 [1/1] [U] md126 : active raid1 sda3 1948663808 blocks super 1.2 [1/1] [U] md127 : active raid1 sdb3 5855671808 blocks super 1.2 [1/1] [U] md1 : active raid10 sda2 sdd2 sdc2 sdb2[1][2][3] 1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU] md0 : active raid1 sda1 sdb1 sdd1 sdc1[3][4][1] 4190208 blocks super 1.2 [4/4] [UUUU] /root/mdadm-detail-scan.txt ARRAY /dev/md/0 metadata=1.2 name=0e34093c:0 UUID=b1079eff:ca275c6a:4df7d648:6f176c9c ARRAY /dev/md/1 metadata=1.2 name=0e34093c:1 UUID=9ecdbab8:7ecf3da9:299f9966:0fa46d04 ARRAY /dev/md/NG-WDRP-6TB-1-0 metadata=1.2 name=0e34093c:NG-WDRP-6TB-1-0 UUID=1d40ffff:601db1f8:20e41e54:f5650fa6 ARRAY /dev/md/NG-WDRED-2TB-1-0 metadata=1.2 name=0e34093c:NG-WDRED-2TB-1-0 UUID=d69ab251:67e359ac:16c640ee:2a0409c0 ARRAY /dev/md/NG-WDRED-3TB-2-0 metadata=1.2 name=0e34093c:NG-WDRED-3TB-2-0 UUID=1c072ab5:ea01a5d6:646d6d07:76776925 ARRAY /dev/md/NG-8TB-Seagate-0 metadata=1.2 name=0e34093c:NG-8TB-Seagate-0 UUID=4a957007:c3c04e0b:0aacb1df:3a59d9e8 /root/btrfs-filesystems.txt Label: '0e34093c:NG-WDRP-6TB-1' uuid: 28fcc8ab-9e63-4529-83f4-1e9d4708bd1b Total devices 1 FS bytes used 4.27TiB devid 1 size 5.45TiB used 4.28TiB path /dev/md127 Label: '0e34093c:NG-8TB-Seagate' uuid: 2a912336-755a-48e6-bcee-fd373ae8e6df Total devices 1 FS bytes used 2.63TiB devid 1 size 7.27TiB used 2.64TiB path /dev/md124 Label: '0e34093c:NG-WDRED-3TB-2' uuid: fbd95853-4f22-4041-8583-4e0853decf9b Total devices 1 FS bytes used 1.17TiB devid 1 size 2.72TiB used 1.17TiB path /dev/md125 Label: '0e34093c:NG-WDRED-2TB-1' uuid: 1b34cda6-1cc8-4360-9ca6-4c209100aa48 Total devices 1 FS bytes used 200.08GiB devid 1 size 1.81TiB used 220.02GiB path /dev/md126 So from the RAID/Btrfs point of view, everything looks consistent: four md data arrays, four Btrfs filesystems, all mounted and in use. There is no extra md device and no Btrfs filesystem corresponding to the blue “RAID unknown” ghost NG-8TB-Seagate volume. What I’ve tried: - Using the GUI “Destroy” on the blue NG-WDRED-3TB-1 volume: it disappears briefly but comes back. - Running btrfs scrub on the real NG-8TB-Seagate volume. - Restarting services and rebooting; the ghost entries and the Inactive/Unprotected log spam persist. What I’m asking for: I’d like guidance on how to safely clean up the configuration/database so that the ghost NG-8TB-Seagate and NG-WDRED-3TB-1 volumes are removed from the ReadyNAS UI and stop generating volume-health events, without destroying the real md124/md125/md126/md127 arrays or their Btrfs filesystems. I’m comfortable with SSH and sqlite3 if needed, but I don’t know the internal ReadyNAS schema, so I’d really appreciate precise instructions like: - which DB file to open; - which table(s)/row(s) represent these phantom volumes; - exactly what to delete/change; - and which services to restart afterwards. I do have backups of the most critical data, but I’d obviously prefer not to wipe and rebuild the entire box just to clear two stale volume objects. Thanks in advance for any pointers.ReadyNas Pro -100
Acquired an Old ReadyNas pro 6 -100 it is running OS6 6.10.9 2GB memory and the 1.8ghz processor Bios is version 1.6 I'd like to update the Bios to version 2.0 for the higher speed FSB memory and Xeon proc. I've stepped through the various bios update pages and continue to fall short on loading the proper updates. I've successfully uppacked the ROM files but when attempting the update or install the dmidecod and flashrom are not available. nor is the libc6.i386. I've attempted to update sources.lists via the old FTP debian Wheezer main non-free and the http://www.deb-multimedia.org non of these pages appear to provide the updated information / install or I'm missing something along the way. Any guidance would be very helpful as I've exhausted my knowledge of next possbile steps. apt-get update # apt-get install dmidecode flashrom - Unable to locate package dmidecode & flashrom # apt-get install libc6-i386 - Unable to locate package libc6=i386SolvedWriting to the LCD (RN516)
Does anyone have any notes on how to enable hardware support or load kernel modules etc, in order to obtain a workable method to access the displays on ReadyNAS devices from within alternative linux OSs? Specifically I'm interested in RN516 and Pro6, but it would be great if we could start to share knowledge to help everyone with this particular issue. I've been running various different OSs on an RN516, and have stuff like fan control sorted. I've also sorted out a nasty ACPI issue which hogs a large chunk of CPU power due to interrupts from IRQ9. But, I've run out of talent so far on anything that lets me access the LCD hardware. Any pointers? And no, there's nothing in /dev like /dev/lcd or /dev/ttyS1 or similar that will do that job. Stuff that works inside ReadyNAS OS6 doesn't work in other linux OSs, presumably due to a lack of hardware support in the kernel, or the correct module. So far I've completely failed to work out how to resolve this. I managed for the fan/temperature/PWM hardware, but the LCD is kicking my butt.661Views0likes8CommentsBest way to swap drives ReadyNAS nv+ v2
I know that my ReadyNAS nv+ v2 is no longer supported, however I would like to use it as a place to store data that can easily be reproduced. I've had it fitted from day 1 with two 3 TB Western Digital WD30EFRX drives using X-raid2 (effectively using RAID-1 giving me 3 TB of net capacity). I got hold of four 3 TB Hitachi DK7SAD300 drives; my plan is to install all 4 drives in my ReadyNAS (giving me 9 TB of net capacity in RAID-5). Here's what I plan to do: Create a backup of the existing data on one of the Hitachi DK7SAD300 drives (done). Remove existing two Western Digital WD30EFRX drives from my ReadyNAS. Install three of the four Hitachi DK7SAD300 drives in my ReadyNAS; perform a factory reset and install using RaidAR version 4.3.8; my plan is to use X-raid2 again, so will end up with a single volume. Copy the data back from the backup created under (1). Finally, insert the final Hitachi DK7SAD300drive in the ReadyNAS (destroying the backup on there). Any suggestions or recommendations? Alternatively, I could create a backup on one of the two Western Digital WD30EFRXdrives (removing one from the ReadyNAS). And configure the ReadyNAS with all four Hitachi DK7SAD300 drives from the start. Only drawback is that I would have to backup my data once more (which will take a couple of days over 1 Gbps ethernet). And should I use or 4.3.8 of RaidAR software? I also came across 6.5.0. Finally, should the above plan hit any issues. Can I still put my two Western Digital WD30EFRX drives back in my ReadyNAS? Thanks!Solved604Views0likes16CommentsNetgear Readynas NVX (Buisness)
I just bought the device for 30 euros and have managed to install the latest official firmware (4.2.31) with Root SSH and fixed the TLS issue. Now I am wondering moving onto flashing something more modern, like Alpine Linux x86. I was wondering if this is possible, advisable and what issues might arise. I have ordered a UART TTL to USB adapter and ask if I would need anything else for this. I appreciate all kinds of feedback. Thanks in advancedHas anyone succesfully updated RNONS6(.10.9) the kernel 4.4.218 to above 4.10 and higher?
Hi, question is simple. I am using RNOS 6.10.9 or 6.10.10 (prefer prelast tuned up version). Has anyone been able and succesfully updated LINUX kernel headers itself at least to 4.10 version and above while keeping ReadyNAS OS installed? I've managed to recompile 4.4.218.x86_64.1. kernel (the available latest linux headers) from public netgear GPL source files for ReadyNAS OS6(.10.9) - package (ReadyNASOS_V6.10.9_WW_src.zip) and there it ends. This allowed me to use 2,5gbit usb-rj45 stick and its driver to improve network transfer speed. But to utilize and use full 5gbit or 10gbit network using rj45 and lan network cable, it requires 4.10 as minimum kernel version at least. Three topics reffering to very same inquiry (i mean updating from 4.4.218.x86_64.1.) https://community.netgear.com/discussions/readynas-use/6-6-0-source-for-kernel-compile/1181799 https://www.facebook.com/groups/NetgearReadyNAS/posts/24065097959771682/ https://www.facebook.com/groups/NetgearReadyNAS/posts/9968858536488861/ Below the line.. i have downloaded original Debian Linux 4.10 (whole genuine package), containing even kernel headers of this version (x86), but i was unable to compile it, fully, getting stuck on LILO or GRUB steps, and linux image update problem, i cant solve. (topic regarding 2,5gbit network usb-rj45 adapter usage connected to usb3 port) https://community.netgear.com/discussions/readynas-general/2-5gbe-usb-lan/2455947 ReadyNAS 312 Thank you
