ip address
3 TopicsDHCP - Need to release IP addresses
Hi, I want a "release" function on UTM50 as it is in many other routers. We often do a lot of test on PDA's and tablets and the IP addresses is not enough. The test itself take maybe 15 minutes and then we take one more units and so on (we also have 5 to 10 units at the same time). The standard lease is 24 h and we have lowered it to 1 h but that is not enough for us. A simple release function should do the trick, then we can release the units we want or just release all. This function is on a lot of routers today.16KViews4likes1CommentReadynas IP address wrong - how do I change it (Mac)
I've just moved offices and have a ReadyNAS NV+ as well as two ReadyNAS OS6's. I've plugged everything back in at the new location and the two ReadyNAS OS6's have picked up the new IP address and are being recognised by readycloud, but the ReadyNAS NV+ is showing a totally different IP address and not recognised by readycloud. When I open Raidar, it picks them all up, showing the difference in IP addresses. I'm sure this is an easy fix, but don't know how. Any help appreciated. Thanks7.9KViews0likes4CommentsGSM7328Sv2 - Factory reset
Wondering if someone can help, we have had this switch for a while and it has been sat in storage for some time. We no longer know the IP of the switch, what subnet it was on etc. After powering it on and letting it boot up, I connect a machine to it and cannot connect to the management interface. It just doesn't want to play ball! If I can get onto the switch and configure its IP, I will install this at one of our other sites, but at the moment I am having some real difficulty getting its IP. I have tried using the Smart Control Center Manager app and it is not detected. Unfortunately we do not have a serial cable to connect to it, cannot run Putty etc. I have tried using the reset button at the front but I have seen online this is for rebooting the switch? Is there anyway to just reset its IP at least so I can get onto the management interface? Any help or points in the right direction would be great! :)5KViews0likes1Comment
