lag
1 TopicNETGEAR Nighthawk X10 R9000 - Firmware Update to Enable Dual WAN Port Bonding - LAG / LACP
Since DOCSIS 3.1 has been released in many markets (Cox, Comcast etc) in the US giving us the consumer options to upgrade to speeds greater to or equal to that of 1Gbps I would like to request to see if it would be possible for Netgear to create a Firmware Update that would give us the ability to Bond two WAN ports with LAG / LACP on the R9000, using the available LAN1 and LAN2 ethernet ports designated for Static LAG or LACP-IEEE 803.3ad. There are now many consumer grade DOCSIS 3.1 Modems that support this due to the fact that speeds are now at or above 1Gbps. In order to bypass the 1Gbps physical port bottle neck, this makes perfect sense. Just for the sake of naming a few modems that have this capability, here I name a few: Motorola MB8600, Arris CM8200, Arris SB8200. I'm sure Netgear will also release DOCSIS 3.1 cable modems that have WAN port bonding simply due to the new speeds of internet available to us via this medium.19KViews1like4Comments
