managed switches
1 TopicGC108PP managed switch: how to change management VLAN?
System -> Management -> IP Configuration has a text box for "Management VLAN ID". I have VLANs configured on this switch. When I try to set the value to anything other than the default of "1", I get a popup stating: "Error! Management access will be lost on MGMT VLAN configuration." No problem I figure, so I click OK. Nothing changes - the management VLAN is still 1. The online help and the owner's manual state that it should be possible to change the management VLAN. I'm running the latest Firmware Version V1.0.8.10. Any ideas?Solved335Views0likes4Comments
