management interface
2 TopicsM4300 routing table Next Hop is Mgmt IP
Apologies for the dumb question: I have two M4300's stacked together with three VLANs configured. VLAN 10 has range 10.0.10.0/24, the gateway is (supposed to be) 10.0.10.1 and the management interface is at 10.0.10.252. However, the routing table for 10.0.10.0 shows the next hop as 10.0.10.252 which must have been set when I chose that IP for the management interface. I was expecting it to be the gateway not the management interface? In "IPv4 Management VLAN Configuration", The management VLAN is 10, Routing Mode is enabled, the IP Address/Subnet Mask are as above and the Gateway is 10.0.10.1. I can ping devices on VLAN10 including the management interface, but not the Gateway. Neither can I ping anything on the other VLANs. Is this normal or have I messed up my config somehow?190Views0likes2CommentsReadyNAS 3100 all disk lights flashing red
I recieved a ReadyNAS NASRNRP4000 last weekend. When I powered it up and the disk failor lights where flashing red in unison. Other servers can access the data, but I can not access it via IP address, RAIDar won't find it, nor can I log into the W2k8 OS via KVM. How should I procead to varify it's health, monitor or access it's management?4.4KViews0likes10Comments
