mobile routers
12 TopicsNighthawk 6200 will not connect to any of my TVs.
My nighthawk 6200 will not connect to any of my tvs. It connects to my phone and computer, has a great signal. The TVs see the signal but will not connect. It connected fine the first day I had the device. We streamed movies and watched the game. Please help.Orbi Mesh System Compatibility with Arris
I am looking at getting an Orbi system for my house. I have an Arris TG1672-NA WifI modem/router currently. The TG1672 combines two analog voice lines, a 4-port Gigabit Router, and 802.11n wireless access point. Are these Orbi systems listed below compatible to my device? Orbi AC2200, RBK20W Orbi AC3000, RBK50 Orbi AC2200, RBK23 Orbi AX4200, RBK752 I appreciate any and all recommendations to include on defining the function (modem or router) for each system.Compatible
I want to buy a Midco Approved Modem that is compatible with a Netgear N600 Wireless Dual Band Gigabit Router Model WNDR3700v4. I don’t know which modem to buy an suggestions. Midco website says that these brands are approved: Netgear, Motorola, Cisco, Arris, Zoom, Hitron.870Views0likes1CommentC7800 model variants
There are two versions of the C7800 model out there and I wanted to know if anyone knows what the actual differences between the two are? I was initially informed that the C7800-100NAS and C7800-200NAS were identical with the exception that the 200NAS came with newer firmware out the box. Supposedly the C7800-100NAS would be a better buy cause it was cheaper for coming with older firmware but would update itself to the latest firmware on connecting to the internet negating any difference between the two. I ended up picking up the C7800-100NAS. After purchase I noticed that on the upper right hand corner of the box where the: C7800-200NAS box says DOCSIS 3.1 Up to 10Gbps my C7800-100NAS box says DOCSIS 3.1 Up to 6GBps I was wondering if this difference came down to a change in firmware or hardware? If it is a firmware issue then does that mean that my C7800-100NAS [running firmware v3.01.43] was upgraded to 10GBps max too or is it relegated to a 6Gbps max?1.5KViews0likes1CommentNETGEAR Nighthawk AC1900 WiFi Cable Modem + Router (C7000)
Hi everyone, I currently have service with spectrum, internet and voice and im wondering if the cables voice internet (calling) (receiving calls) interferes with my internet connection/wifi.With spectrum internet + voice i have a splitter connected via a coax cable to my NETGEAR Nighthawk AC1900 WiFi Cable Modem + Router (C7000) for internet and my ubee voice for calls. I want to know if i connect to my ubee voice's internet to check youtube and watch netflix will this interfere with my brothers gaming. Im just wondering if i use the ubees voice internet will it affect my internet speed causing latency lag since internet and voice are connected through the splitter. One coax cable to my netgear modem/router and another coax cable to my voice ubee. I get 100 mbps with my internet and 70 mbps in ubee voice internet. If someone can rephrase this or help me understand i will greatly appreciaate it. Anywhere else i can post this (forums or somewhere where they could help me please let me know.1.1KViews0likes2CommentsParental Controls on Nighthawk App
I have a Netgear router purchased in 2018 that I set up with the Genie app including the parental controls. I haven’t done anything with it since but need to change the settings now. The Genie app isn’t supported anymore so I downloaded the Nighthawk one and can’t find the parental controls anywhere. It’s driving me crazy! Please help!1.7KViews0likes1CommentA7000 Connection Difficulties
I brought a desktop that was not wifi-enabled to college with me. At the start of the semester I purchased the A7000 and had no issues connecting to my college's student wifi (Which is WPA2). I've been using it with absolutely no complaints since August. However, today I returned from a midterm needing to use the Internet to complete some of my classwork and the A7000 was turned off. I restarted my computer probably a half a dozen times before reinstalling the drivers and that generally fixed the issues with getting the A7000 to actually turn on. Problem solved, I thought. Nope! I now cannot connect to the wireless at my school. I can only manage to post this discussion using my phone's hotspot. I'm not super well-versed in working with this sort of stuff. The only thing I've noticed is that my computer cannot connect to anything that's WPA2 (The wifi I WAS using) now. Only WPA2-PSK (My phone's hotspot). Any help would be seriously appreciated.1.4KViews0likes1CommentROUTER ACCT LOGIN FUSTRATION
I'm trying to get into my Router Account to get to the genie parental controls, but it says "invalid username or password", i've tried everything, loging in with admin-admin, admin-password, etc... but nothing works! Can anyone help? Router model is ac 1900 c7100v1.8KViews0likes3CommentsEverything is WRONG with this so called Router/Modem
Since day one of purchasing this C6300 router/modem in one I have only had problems, and of course NetGear wants $50.00 to even ask a question so right now I'm so frustrated I want to scream! First the problem was signing on and getting kicked right back off. Then I began receiving messages like "your NetGear certificate is expired or no good" I attempted to figure out the problem with no luck. I cannot enable my bluetooth devices, and I continue to have problems each day with wifi connections. When I look at the properties of my connection it says "Qualcomm Atheros QCA61x4A Wireless Network<adapter" PLEASE, if someone could tell me what this means? It is associated with Microsoft and was istalled in the last few months. Why? I have no idea. I have downloaded the NetGear Genie, which show about the size of two postage stamps put together, so I have to use a magnifying glass to read what the page says. When I was finally able to read it the message is "NetGear Router is not installed." I have attempted to find out if I can reinstall, but can't find anything and don't have the money to ask support. I'm going crazy! If someone has ideas I would love it!Solved1.1KViews0likes1Comment
