no connection
2 TopicsI can't connect to the wifi extender on my iPad or PC but every other device works.
Yesterday my connection to my EXT6100 AC750v2 just cut out on both my iPad and PC at the same time with no warning. I checked the extender and it was still plugged in and both of the green lights were on (one signifying a connection to the router and the other a connection to a device). Every time I entered the password on my iPad for the extender to reconnect, the prompt would just disappear and then reappear as if I didn't do anything. My PC will also just fail to connect to the network. I have tried restarting the extender, restarting the modem, rebooting both devices, re-syncing WPS on the extender and the modem and I end up with the same result, only now the light to signify a connection to the device just isn't on. ALL other devices in the house can connect to the extender with no issues. The firmware is up to date (version 1.0.0.50 I believe?) and I'm currently trying to find an ethernet cable for a direct connection to the extender to see if that helps. Any suggestions would be appreciated. ThanksSolvedUnidentified Network through wired connection
Hi, I've been having trouble getting a wired connection with my Netgear Extender after we replace our Xfinity router due to the previous one being fried during a storm. It's been giving me Unidentified Network/ Ethernet doesn't have a valid IP configuration. My current setup is a Cisco Xfinity Modem/Router Hybrid Model DPC3941T in the main office on the main floor and the EX7300 Netgear Extender in the basement set up as an extender. WiFi is strong and is working normally, only the wired connection is giving me a hard time. I have some knowledge/experience with troubleshooting and have already tried most of the basic troubleshooting steps to see what was wrong. - Factory reset the extender / modem / router - Replaced ethernet cable - Used a switch between the extender and computer - Did multiple ipconfig /release /renew with no results - Did the netsh commands to reset TCP/IP reset - Uninstalled the network driver / reinstalled with the current driver / tried using older driver - Did sfc /scannow - Gave the extender a static IP - Gave the computer a static IP / 10.0.0.1 / 192.168.1.1 / 192.168.0.1 as gateways I am getting a connection from the ethernet port on the EX7300 so it's not hardware related and more on the computer side. I've probably visited hundreds of sites and forums and tried the solutions there but my situation stayed the same. Here's my ipconfig /all Windows PowerShell Copyright (C) 2016 Microsoft Corporation. All rights reserved. PS C:\WINDOWS\system32> ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : Ethernet adapter Ethernet: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Autoconfiguration IPv4 Address. . : 169.254.144.207(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.0.0 Default Gateway . . . . . . . . . : DHCPv6 IAID . . . . . . . . . . . : 273468522 DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Phantom TAP-Windows Adapter V9 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Connection-specific DNS Suffix . : hsd1.va.comcast.net Description . . . . . . . . . . . : ASUS PCE-AC88 802.11ac Network Adapter DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : Lease Obtained. . . . . . . . . . : Saturday, June 17, 2017 7:25:00 AM Lease Expires . . . . . . . . . . : Thursday, June 22, 2017 10:48:43 AM IPv6 Address. . . . . . . . . . . : Temporary IPv6 Address. . . . . . : Link-local IPv6 Address . . . . . : IPv4 Address. . . . . . . . . . . : 10.0.0.156(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Saturday, June 17, 2017 7:25:00 AM Lease Expires . . . . . . . . . . : Saturday, June 24, 2017 7:25:08 AM 10.0.0.1 DHCP Server . . . . . . . . . . . : 10.0.0.1 DHCPv6 IAID . . . . . . . . . . . : 137664502 DNS Servers . . . . . . . . . . . : 75.75.75.75 75.75.76.76 75.75.76.76 75.75.76.76 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Bluetooth Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Tunnel adapter Teredo Tunneling Pseudo-Interface: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes10KViews0likes5Comments
